Time to tidy the garage up. All prices inc. UK post. Discounts for multiple buys. Collection from Newcastle available with discount.
More pictures of everything here: https://www.flickr.com/gp/136120472@N08/t82ThC
Alloy seatpost mount rack - £15 posted
QR clamp to seatpost (think it's for a 30.9 but will probably fitter wider and can be shimmed). Well used so bits of rubbing in places. I added a brace between side bits (a bit of aluminium plate and a couple of P-clips) to stop them bending in when I was probably carrying more than it was designed for. I'll leave these on in case they're useful but they just unbolt.
IMGP3715 by Dave W, on Flickr
Dawes 38cm drop bars with 80mm stem - £15 posted
Pretty standard alloy drops. Came off a new bike and I used them a few times to try out drops on a bike. Some residue from tape I used to protect them from the levers but otherwise as new. 31.8mm clamps on both bar and steerer. Think the stem is 10deg rise. Will include bar tape below free if not already sold. Could sell separately, make me an offer.
IMGP3719 by Dave W, on Flickr
Bike Ribbon Professional Bar Tape - £4 posted
I've used a little for some bar ends, but still a single 180cm piece left so should do most bars as long as they're not massively wide or you need to wrap all the way to the stem. Boxed but will take it out to make postage cheaper if bought separately.
IMGP3732 by Dave W, on Flickr
Easton EC70 carbon flat bar - 580mm wide - 25.4mm clamp - a few degrees of backsweep - £15 posted
130g. Plenty of scrapes from controls/stem, still solid.
IMGP3725 by Dave W, on Flickr
Shimano Shoes and Cleats - £20 posted together
Bought used to try (cleats were new), gone back to flats.
SM-SH56 Cleats. Multi-released. Used for a few rides so some surface corrosion, but very little wear. £6 posted.
IMGP3773 by Dave W, on Flickr
SH-AM30 Shoes, size 46. Barely used, almost no wear to soles. £25 posted.
IMGP3779 by Dave W, on Flickr
Hope 183mm rotor - £10 posted
Unbranded 185mm rotor - £8 posted
Both 6 bolt, straight so far as I can tell.
IMGP3735 by Dave W, on Flickr
IMGP3741 by Dave W, on Flickr
Hope HBSM20H Front IS to post 20mm adapter
Hope HBIS20 20mm IS adapter with bolts
Perfect condition.
£8 posted each
Brand new 48t alloy chainring, 104BCD, 89g - £12 posted
IMGP3759 by Dave W, on Flickr
IMGP3764 by Dave W, on Flickr
Forgot to take a photo of the other one, can do if necessary, but it looks like all the other HBSM20H adapaters on the internet.
Altura pannier replacement lower rail and hook - £4 posted
Should fit all Altura panniers.
IMGP3762 by Dave W, on Flickr
Ibera bar-mounted cupholder - £5 posted
Fits all bar widths. Holds tapered cup/flask. 80mm diameter. As new.
IMGP3730 by Dave W, on Flickr
Shimano Exage FC-M520 175mm cranks and Shimano 26t ring - £10 posted
Grey. Retro. 5 bolt. Scraped but good threads/tapers.
IMGP3765 by Dave W, on Flickr
Sakae SX Ovaltech chainset - £10 posted
Extra-retro. 5 bolt. 170mm. Needs a good clean and cheap plastic pedal removed, probably with some "encouragement."
IMGP3783 by Dave W, on Flickr
Clearout - Shoes, Bars, Brake bits, QR rack, etc., etc.
- thenorthwind
