Small fuel bottle cage?
- summerwastin
I have an 11oz (small) msr fuel bottle that is too small for a normal bottle cage. Anyone know of a mini bottle cage that would take a bottle like this? Ta
Re: Small fuel bottle cage?
Monkii
What's the diameter of the bottle?
- summerwastin
the diameter is about 6.5cm
i've clocked the monkii ones - probably a good bet.
thanks
thanks
Do you want me to try one?'ve clocked the monkii ones - probably a good bet.
If you can find one, the Elite Carbon 19 cage is designed for a custom smaller diameter bottle, it's 66mm so perfect for your use. I got one from Planet X, they're showing 1 left in stock but I'd take that with a pinch of salt.
http://www.on-one.co.uk/i/q/BOC19BC/car ... ottle-cage
Try eBay as well.
Try eBay as well.
- summerwastin
thanks I'll check them out too. ta
- summerwastin
you mean test it yourself? yes please... that would be great.Bearbonesnorm wrote:Do you want me to try one?'ve clocked the monkii ones - probably a good bet.
Just tried a 65mm bottle in a Monkii - very secure
Have a look at Elite Pave' bottle cage too, it has an adjusting wheel on the front to tighten it.
£7 too at present
https://www.athleteshop.co.uk/elite-bot ... 7Qodw1YDwg
£7 too at present
I ran a small trangia fuel bottle in a monkii before, was fine
- summerwastin
gonna go monkii i think. its future proof after all - they fit everything it seems! thanks for the advice
