BareBones Fatfighters - The weigh in
NorwayCalling
Post by NorwayCalling »
Hello and welcome to the place to record your stats for the grand BBFF challenge. Its quite a simple process and hopefully with a little mutual support, we can all archive our goals in 2017. If you are not familiar with this then have a look here: http://bearbonesbikepacking.co.uk/phpBB ... f=7&t=8939
There are no rules or other such things but this is is how it goes.
1. Post your starting weight and any other dimensions you fell like sharing.
2. Weights will be recorded every 2 weeks, Thursday morning is what I am thinking (but its up to you).
3. Some idea of what you would like to achieve would be nice (i.e. I would like to loose 20 cm from around my gut and 10 kg in weight)
4. Update your original post with your new weight every 2 weeks and see how it goes (add a new line per entry).
I will be keeping a spreadsheet on this and will post some stuff up as we go along.
So good luck to all in 2017.
NorwayCalling
Re: BareBones Fatfighters - The weigh in
NorwayCalling: My goal: simple, change crap eating and get down to 80.0 kg by 31.12.17
01.01.17:
Weight: 90.6kg
Gut (relaxed - not breathing in i.e. the full horror) 106cm
BMI (NHS measurement): 28.6
12.01.17
Weight: 87.9kg (-2.7 kg overall, -2.7kg in last 14 days)
Gut: 103cm
BMI: 27.7
26.01.17
87.6 kg (-3.0kg overall, -0.3kg in last 14 days)
09.02.17
85.5 kg (-5.1 kg overall, -2.1 kg in the last 14 days)
23:02.17
85.2kg
(-5.4 kg overall, -0.3 kg in the last 14 days)
09.03.17
86.0 kg
(-4.6 kg overall, +0.8 kg in the last 14 days)
23.03.17
85.9kg
(-4.5 kg overall, -0.1 kg in the last 14 days)
06.04.17
85.0kg
(-5.6 kg overall, -0.9 kg in the last 14 days)
4.5.17
84.8 kg
Last edited by NorwayCalling on Thu May 04, 2017 9:22 pm, edited 10 times in total.
Moder-dye
Post by Moder-dye »
Moder-dye; goal 190lb
1/1/17. 241.8lb, waist at BB 106cm
15/1/17. 242.2lb. Waist at BB 106cm :cry:
23/1/17. 236.8lb. Waist at BB 104.5cm
28/2/17 238.8 :oops:
Target: 65 kg
01/01/2017: 71.0 kg | BMI 23.2 | gut 85 cm
11/01/2017: 69.4 kg | BMI 22.6 | gut not measured
22/01/2017: 69.2 kg | BMI 22.5 | gut 81 cm
27/01/2017: 68.4 kg | BMI 22.3 | gut 80 cm
10/02/2017: 68.1 kg | BMI 22.2 | gut 80 cm
24/02/2017: no measurements
10/03/2017: 65.8 kg | BMI 22.5 | gut 78 cm
24/03/2017: 65.5 kg
02/04/2017: 64.6 kg | BMI 21.0 | gut 77 cm
13/04/2017: 64.4 kg | BMI 21.0 | gut 74 cm
godivatrailrider
Post by godivatrailrider »
Martin
01/01/17
Initial Goal ? anything starting with 15st would be good...... 14st something would be vaguely exciting
17st 6.8lb :???:
Goal of 80Kg
1/1/2017: weight 87Kg | BMI 26.8 | gut 95cm
15/1/2017: weight 87Kg | BMI 26.8 | gut 95cm
27/1/2017: weight 85.5Kg | BMI 26.4 | gut 94cm
10/2/2017: weight 86Kg | BMI 26.5 | gut ??
24/2/2017: weight 85Kg| BMI 26.2 | gut ??
10/3/2017: weight 85.1Kg |BMI 26.2
1/4/2017: weight 83.5Kg | BMI 25.7
5/5/2017: weight 85Kg | BMI 26.2
19/5/2017: weight 84.6Kg | BMI 26.1
133 kg
target
115 kg
quimarche
Post by quimarche »
01/01/2017: 237.2 lb
08/01/2017: 233.4 lb (-3.8 lb)
14/01/2017: 232.4 lb (-1.0 lb)
22/01/2017: 230.6 lb (-1.8 lb)
04/02/2017: 229.6 lb (-1.0 lb)
18/02/2017: 228.4 lb (-1.2 lb)
19/02/2017: 227.2 lb (-1.2 lb)
11/03/2017: 227.0 lb (-0.2 lb)
18/03/2017: 228.2 lb (+1.2 lb)
25/03/2017: 228.4 lb (+0.2 lb)
01/04/2017: 231.0 lb (+2.6 lb)
08/04/2017: 228.4 lb (-2.6 lb)
22/04/2017: 231.0 lb (+2.6 lb)
29/04/2017: 228.6 lb (-2.4 lb)
13/05/2017: 227.4 lb (-1.2 lb)
22/05/2017: 224.5 lb (-2.9 lb) post-JennRide
10/06/2017: 229.8 lb (+5.3 lb) back on the wagon
17/06/2017: 226.6 lb (-3.1 lb)
24/06/2017: 227.0 lb (+0.4 lb)
09/07/2017: 227.2 lb (+0.2 lb)
15/07/2017: 225.4 lb (-1.8 lb)
23/07/2017: 227.2 lb (+1.8 lb)
04/11/2017: 229.6 lb (+2.4 lb) where did the summer go?
02/01/2018: 233.6 lb (+4.0lb) 2018 *will* be better!
31/12/2017: 175.0 lb
TheBrownDog
Post by TheBrownDog »
01.01.17
Weight 98kg
Target 90kg
Lump
Post by Lump »
Dont have any scales in the house, so im going with feel. 34 waist down to owning a pair of 30's will do
gazaddy
Post by gazaddy »
01/01/17 - 90kg
Target - 80kg
--------------------------------------champagne lifestyle on lemonade budget
Eaten too much cake over Xmas and up to
1/1/17 83kg
Goal for summer 76kg
A fraction over a stone in real money.
Still in 32" waste jeans but it would be nice to have them baggy around the waist.....
gypsumfantastic
Post by gypsumfantastic »
Current
01/01/2017 - 84.2kg NHS BMI - 23.8
Goal
01/07/2017 75kg NHS BMI - 21.2
Total loss 9.2kg (20lb ish in old money) I'd tolerate 77kg and be amazed to get below 75kg
Dr Nick
Post by Dr Nick »
Dr Nick:
Current 1/1/17
78.8kg
BMI (NHS) 27.2
Belly 97cm
Height to waist ratio .58
(Peak flow 450)
Target 70 kg
BMI 24.2
Less belly ( .5 ratio is 85cm ) and better lungs.
Good luck all.
Edited to add running total:
1/1/17: 78.6kg
12/1/17: 76.8kg
28/1/17: 76 kg
10/2/17 75.2 kg
23/2/17 74.3 kg
10/3/17 74.3 kg
03/04/17 75.8 kg :cry:
08/05/17 76.2 kg
29/06/17 77.6 kg
06/07/17 77.0 kg
03/08/17 76.0 kg
31/12/17 79.5 kg
metalheart
Post by metalheart »
mh:
Current - fucking heaps... :oops:
111 kg. there I've said.
Objective - heaps less.
Sub 100kg by the end of May
Long term objective to be sub 89 as that is the 'tipping point' where climbing stops being oooof and starts being fun...
Thinks scales were broken this morning (or I've gained 1.5kg overnight :shock: ). Will try again tomorrow am.
ETA: weigh in/objectives added. 03,01
Give the dirt a little room.
Richard G
Post by Richard G »
I've gained 1.5kg in a day before now... it can happen. Generally just water weight though.
No scales here. Will weigh when I'm back off my holiday. I'm sure it'll be horrifying.
First goal is 60kg or 9.9% body fat (unlikely) by March 14th.
07/01/2017: 65.0kg
14/01/2017: 63.7kg
21/01/2017: 63.4kg
04/02/2017: 62.7kg
18/02/2017: 62.1kg
25/02/2017: 62.1kg
04/03/2017: 60.8kg
11/03/2017: 61.6kg (Oops! Still, it was a fun weekend.)
18/03/2017: 61.5kg
25/03/2017: 60.4kg
01/04/2017: 59.5kg (Done! Now to find my maint level)
Second goal is staying between 60kg and 61kg eating slightly more on weights days, and slightly less on cycling days. Trying to gain a bit of muscle, but not put on too much fat.
08/04/2017: 60.4kg
15/04/2017: 60.0kg
22/04/2017: 61.5kg (This looks worse than it is, it's because of the average being messed up by 4kg of water retention on one day)
29/04/2017: 60.8kg
06/05/2017: 61.9kg
13/05/2017: 61.1kg
20/05/2017: 62.1kg (Injured)
27/05/2017: 61.7kg (Injured)
03/06/2017: 61.2kg (Injured)
10/06/2017: 61.1kg (Injured)
17/06/2017: 62.2kg
24/06/2017: 62.2kg
01/07/2017: 62.8kg
08/07/2017: 61.7kg
15/07/2017: 62.3kg
22/07/2017: 61.9kg
29/07/2017: 61.2kg
05/08/2017: 60.7kg
12/08/2017: 59.9kg
Third goal, lean bulk to around 63kg. I need some muscle back, especially after last year's injuries. If that makes me a tiny bit slower up hills. So be it.
19/08/2017: 61.4kg
26/08/2017: 61.6kg
02/09/2017: 62.6kg
16/09/2017: 63.5kg
30/09/2017: 63.2kg
14/10/2017: 63.9kg
...and I broke a rib at the BB200, followed by a trip to America. Time for the wheels to fall off!
28/10/2017: 65.7kg (Injured)
04/11/2017: 66.1kg (Injured)
11/11/2017: 65.9kg (Injured)
18/11/2017: 66.4kg (Injured)
25/11/2017: 67.1kg :cry:
I'll get back on it. Somehow.
99percentchimp
Post by 99percentchimp »
Mark (99%chimp)
Current stats
Date - Weight (kg) - BMI - Waist (cm) - Thigh (cm)
1/1/17 - 107.6 - 29.6 - 104 - 70
Goal 1 (end May) - weight 94 kg (BMI of 26)
Goal 2 (this year) - weight 86 kg (BMI of 23.8)
Conquistador of the pointless
firestarter
Post by firestarter »
2/2/17 194lbs 88kg or 13St 11 3/4lb fatty bumbum
Like to get down to 12 to 12 and a half stone
Blair512
Post by Blair512 »
Our scales have conveniently ran out of battery. Will try to get one today and update tomorrow morning.
RobMac
Post by RobMac »
2/1/17
Height : 5'10" / 1.780 mtrs
Weight : 13 st / 82.5 kg
Target
12 st 7 lbs / 79.3 kg Realistically
12 st 0 lbs / 76.2 kg Would be a bonus
Last year I had heart surgery so I'm not putting strict time scale on this, BUT I'm planning on doing the full Scottish Enduro Series AND getting out loads on my new bikepacking dedicated bike, ALSO getting back to riding to work as often as possible (40 mile round trip), think thats enough for getting on with at the moment :-bd
gairym
Post by gairym »
Now mid-June and despite being in pretty good bike-shape I've yet to keep any weight off since the start of the year.
It's an annoying undulation of progress and then relapse - I'm back at it now so let's hope I can keep my sh1t together this time.....
Gairy Mannion - Target weight: 90kg (and eventually lower)
Start weight -01-01-2017:
110kg
09-01-2017:
108.9kg
16-01-2017:
107.8kg
23-01-2017:
107.2kg
31-01-2017:
108.4kg
21-02-2017
106.5kg
20-03-2017
105.5kg
04-05-2017
109.5kg
21-06-2017
108.4kg
Fat tyre kicker
Post by Fat tyre kicker »
FAT tyre kicker;
After the scales had recovered - 18 stones 3 pounds - height 5' 11 ish
Target weight.....anything lower than that so I can cycle more enjoyably,to be fair
The festive season hasn't added much, going on no/few carbs kind of thing that
Will suit me, wifey and daughter tagging along too but not with the full fat milk etc.
Been trying to get a ride a week in recently but that went off the rails last week,
Going to Llandegla in the morn for meet up/catch ride,not really my kind of thing
But at least it's out. Was hoping for a new frame this week but life responsibility's
Might have kyboshed that.....got a lovely set of 27.5+ rims here now, may have to
Just get hubs that match what I've got now...... :-bd
2/1/2017 18st 4 - 116.1 kgs. 25/3 17st 8 :|
9/1. 18st 3 - 115.7. 8/4. 17st 8 ish....
16/1. 18st 4 - 116.1. 19/5. STILL 17st 8 ish..
23/1. 18st 1 - 114.8
30/1. 18st 1 - 114.8 :roll:
6/2. 17st 11 - 113.18
13/2. 17st 11 a 113.18 :roll:
21/2. 17st 12 a :|
6/3. 17st 9 :grin: 112.27
20/3. 17st 8 ish 111.8.
3/3. 17st 8. 111.8 :|
Last edited by Fat tyre kicker on Fri May 19, 2017 12:39 pm, edited 12 times in total.
breff
Location: Lancaster.... "Not the Yorkshire, Not the Yorkshire!"
Post by breff »
Heaviest I've ever been and the Diabetes is going to start taking my legs and my eyes iff'n I don't Fettle a Fat Dog!
As of 1st January 2017
Current start point.
Height :1.730 mtrs
Weight : 127.1 kg
Target
90.00 kg Realistically
80.00 kg Would be as good as it could get.
At the pace of sailing ships and bicycles.
bearlymoving
Post by bearlymoving »
As of 3 January, I'm 84.7kg (13.5 stone), 6' tall, with a BMI of 25.3. Measurement around the gut is 35 and 5/8" (90.5 cm).
I'd absolutely love to be 12.5 stone, or get down to 80kg. 12.5 stone is 79.3kg, so that'll be my target. It sounds unachievable right now, but let's see.
I've just done the festive 500 and can tell from my jeans that I'm a good bit slimmer as a result. My immediate challenge is going to be to avoid putting that weight back on.
I only got some scales yesterday; it's a shame I didn't monitor the impact that 500km actually had. :-(
SeannyD
Post by SeannyD »
As of today 105.8 kg BMI 32.7. I've put on 3.2 kg over the festive period.
Would like to get to 88kg (14stone in old money) by the summer.
My plan is to eat less, exercise more and no alcohol during the week too :sad:
