Size large / 58 and black - see http://www.cotic.co.uk/product/x Its actually a small size large if you get what I mean and would suit someone from about 5'7"- 6' ish. Seat and sloping top tube are booth 54cm. I'm selling as it was always a bit on the wee side for me (6'1")
I bought this new in April 2011 and used it regularly (on road only) until Summer 2014. Its fitted with a steel road rat fork which I got as a warranty replacement from Cotic as the original Carbon Fibre fork cracked. The fork is disc only but the frame has canti mounts. Overall its in good condition with only some minor scuffs, a scrape on the inside of the LH chainstay from the disc and a couple of chips on the down tube on the sticker which I've touched up. Its waxoyled inside and rust free. Its fitted with a Cane Creek headset with good bearings.
I'm looking for £150 posted or a bit less if you collect from my place in Fife.
Pics!!
Phil
Cotic X frame and forks now SOLD
Re: Cotic X frame and forks
Am waitinhtrider wrote:
I'll post up some pics once the bloody photobucket website is working again!
Phil
registering interest, just having a little read up on them
Also registering interest, dependent on pictures, possibly without the fork if you'd be willing to do that?
If the fork has the brake in the normal position(i.e. behind left leg) and is cheap I might be interested in that. Can't fit a dynamo to my current one with the 'other side' brake.
Pics now added. If anyone can reccommend a better photo hosting website than photobucket (of sh**e) let me know....
Re the forks - as you will see they are the ones with the caliper mount on the RHS facing forward. This looks weird but works fine and possibly reduces the amount of muck getting into the caliper....
I'd rather sell complete but will split if all else fails
Phil
Phil
I'd like it, but it seems I'm not at the front of the que. Definitely want it though.
Ah, those forks are the same as mine- fine for forking and braking, awkward for dynamos.
Cheers though!
Cheers though!
Thanks for the interest folks, just to update you all Rob Mac has first dibs and is coming to have a look next week. Ben, your next in line
Phil
Phil
