I'm looking for a pair of 3/4 bib shorts that will actually fit me. I'm 6ft 1" with a 32 inch waist and none of the shorts I look at seem to scale right for someone of my build. It seems as though I'm expected to be far larger than I am for my height. Anyone got any recommendations?
Many thanks
Ben
Bib shorts help
Re: Bib shorts help
I like a bit of versatility in clothing, so I'm going to recommend getting some knee warmers instead.
Re: Bib shorts help
Similarly shaped.
Endura tend to be ok - but the best fitting 3/4s I have are Castelli.
Re: Bib shorts help
I'm 6ft and 30in waist. Often end up buying small bib-shorts. Usually fine, if a little shorter on the leg. Morvelo gear fits me well (in a medium). Really rate the pad they use and their 3/4s as well.
Re: Bib shorts help
Comfort wise, Crikey, how much.
Can't help you with sizing though!
Re: Bib shorts help
Ben
Try Pearl Izumi Attacks - I'm about your dimensions and size large fits well.http://www.fatbirds.co.uk/122026/produc ... GwodPV8IHg
All day comfort as well.
Re: Bib shorts help
Same dimensions as you and the DHB bibs in medium fit me well. Bear in mind that bibs should feel tight when you're stood up straight, when you're in the saddle your body will be "shorter" and you shouldn't have a problem!
Re: Bib shorts help
Yep, expensive but worth it. Best thing is that they are free returns so order in a few sizes and send back any you don't want once you've tried them.voodoo_simon wrote:Comfort wise, Crikey, how much.
If you can live with a bit of sky branding they've got 40% off.
http://www.Crikey, how much.cc/gb/en/shop/team-sky ... y/team-sky
