dynamo lighting ?
dynamo lighting ?
is it possible to run 2x exposure revo s and rear red eye from an sp pd8x hub,
Re: dynamo lighting ?
Maths says no.
The hub is limited to 6w
You even notice the light needing you to go faster to give full 4 led power with the red eye in than without. I reckon even if it were possible it would have only given full power as you approached mach 1
You could charge a diablo during the day off a usb converter and use that in conjunction with the revo at night to give plenty lumens.
