Bib Shorts
Bib Shorts
Anyone have any recommendations for bib shorts that have minimal/no padding?
Finding that the padding becomes sweaty after a days worth of riding and that not helping my undercarrage the next day.
Like my Gore bibs but the feeling isnt being reciprocated at the moment.
Re: Bib Shorts
Castelli are minimal in the padding area
- Chicken Legs
Re: Bib Shorts
2XU Tri shorts have a very a very thin pad but they might be too thin !!
Re: Bib Shorts
was going to recommend the same. Tri gear is very little padded as you want to swim, run, ride in it.Chicken Legs wrote:2XU Tri shorts have a very a very thin pad but they might be too thin !!
I use Assos but those are like nappies. Thick and heavily padded.... but soooo comfy (for me) for any kind of length.
Saying this because it may be more down to solid moisture management of the chamois then solely it's thickness. Chamois cream may help too.
Re: Bib Shorts
Clean them with anti-bacterial wipes. They take up next to no space. Turn them inside out and let them dry properly.
I've managed 8 days riding on the bounce with the same pair of shorts like this.
Re: Bib Shorts
Another thumbs up for Assos. Expensive but I have zero regrets. Happily do 12 hour days and then ride the next day. I do use the creme.
Re: Bib Shorts
I'm sure I've got some Polaris ones that don't have any padding as standard. All my others, I've just unpicked the stitching and thrown the offending pad in the bin.
Re: Bib Shorts
I like endura shorts/bibs. With the cool max pad. The gel pads don't wick moisture away as well. The endura pads are reasonably thin and are good day after day. And they are not rediclously expensive.
Re: Bib Shorts
Then why bother with cycling pants in the first place?Bearbonesnorm wrote:[...]All my others, I've just unpicked the stitching and thrown the offending pad in the bin.
Re: Bib Shorts
I don't usually but in winter, sticking a pair of bibs beneath your shorts obviously helps keep you a lot warmer.Then why bother with cycling pants in the first place?
Re: Bib Shorts
Ah... now I get it, running tights et al. don't come as bibs.Bearbonesnorm wrote:I don't usually but in winter, sticking a pair of bibs beneath your shorts obviously helps keep you a lot warmer.Then why bother with cycling pants in the first place?
