[Need help] Headset for Genesis High Latitude
piotr
Post by piotr »
Any recommendations on a headset for a Genesis High Latitude (29er 2015) frame? It's an oversized 44mm headtube. I'm not sure what will work. Thanks.
Lump
Re: [Need help] Headset for Genesis High Latitude
Post by Lump »
Hope pic n mix is 2 H Just bought them from wiggle as they were running 20% off
As above, the Hope pick and mix are suitable, the top cup Type 2 (Integral) for 1 1/8" steerer and bottom cup Type H (Traditional) for 1.5" steerer. The bottom cup puts the bearing below the head tube and allows the use of a tapered steerer fork.
If you have a straight 1 1/8 steerer fork then the bottom cup to use is Type B (Integral)
Hope have a handy fitting chart which helps with the minefield which is modern bike 'standards' :???:
http://www.hopetech.com/wp-content/uplo ... -CHART.pdf
There are cheaper alternatives but my experience of Hope headsets is that they are fit and forget so well worth the extra cost.
Sean
piotr
Post by piotr »
Thank you guys :-bd
