Dull guessing game post.
Would anyone* care to guess what the specific use for this item is? ... it is bikepacking related.
*apart from Brother Smith.
Matt
Re: Dull guessing game post.
Post by Matt »
It's smaller than the photo suggest.
I reckon its a "separator & holder"
No getting owt past you is there?
Taylor
Post by Taylor »
To hold poles either side of his frame.
No but on the right lines.
Ben98
Post by Ben98 »
Holding brake/gear cables out the way of a bar harness?
Shove the poles through the pipe?
No
Eh?
barney
Post by barney »
clips look too big for poles so I guess they go on the bike somewhere like the seatpost/frame
Is it some sort of fancy aid to carry a bike on your shoulder through a nasty BB200 hike-a-bike section?
Wait for me...
No
and no.
Taylor's nearest so far ... obviously Zippy might be nearer but until someone can decipher, we won't know.
Is it for holding your handlebar in a fixed position while you use it to support your tarp?
Eh?
s8tannorm wrote: Taylor's nearest so far ... obviously Zippy might be nearer but until someone can decipher, we won't know.
I er mean do you put the poles through the middle of that hose section, so you can then hang er socks or tie guides or something to it? Or it allows adjustment of clips up and down a pole for something....Image just not quite sure what.
There's gotta be some reason for it being a hose though
Love that thinking smiley you've used there Zippy :lol:
Ian wrote:Is it for holding your handlebar in a fixed position while you use it to support your tarp?
or between fork leg and down tube, or summat along those lines.
Okay, some good guessing but nothing quite right.
A few clues ... it is something to do with poles, it isn't anything to do with the actual bike. Think how it might be used with a shelter.
Lughnasadh
Post by Lughnasadh »
Is it a ridgeline for a very small tarp set up?
Fat tyre kicker
Post by Fat tyre kicker »
Well,I've looked,it's not on Ann summers website :YMDEVIL:
Hold together two poles so you can have a wider entrance at the front of a pitch
Mart
Post by Mart »
you clip it between parts of your frame to act as a washing line to hang your teatowel off ?
Brother Smith has an MLD 'mid and wanted to use 2 poles rather than 1 ... as Ben says, to increase the internal space and make entry / exit easier. The problem with using 2 poles to form an A frame is trying to hold the things together / inplace while you get it pitched, hopefully this is a solution.
Told you it was dull :wink:
Zippy wrote:
s8tannorm wrote: There's gotta be some reason for it being a hose though
Hmm, turns out that reason is flexibility and nothing to do with the putting stuff down the hollow bit :lol:
Awesomes, so I win?!
Which mid?
I have a Spinntex Mid, which is a spinnaker supermid. It's massive so not short of space, but if I want more on one side I tend to lean the poles rather than put them upright
I've been meaning to get you to make me a pole for it but in reality I only use it if I'm walking so I use walking poles. One day I'm going to find time to do a motorcycle tour, i'll be sending my request in then.
golite used to do an adjustable pole that was perfect, but they stopped sending stuff to the UK, and then went bust!
But pretty hefty I recall?
Probably
I like the ability to give me a way of adjusting the height by a few inches though, gives me a ability to vent or button down the hatches
Brothersmith
Post by Brothersmith »
Cheers Stu, poles landered yesterday. Had family here this wkd so not had a chance to do garden test pitch yet. Look good though
benp1 wrote:Awesomes, so I win?!
Which mid?
It's a Solomid, kicked pole works but still eats internal space. It's also stronger and taught ear with A frame pitch
