Bringing things even further back down to earth (well, to a boot sole's height above it ) are my two pairs of "Profoot Double Deodorising Insoles". Brilliant they are. Not sure what the "double" bit is - makes my feet smell twice as nice?
R
R
Picked up a wheelset at the post office. Carbon rims and DT 350 hubs, DT Comp spokes and brass nipples.
Looking forward to my new geeked out long travel trail bike and some Alpine trail hammering
a little wonky ring to go on my shorter cranks
Let the experiment continue
- TheBrownDog
One of these arrived today. I have an old piece of carbon felt in a box somewhere which I reckon will make a nice bed for 40ml of meths, which should be enough to do two maybe three boils with my Stormin Stoves cone. Maybe.
I made one with a Vaseline tin - meths burner using mesh and kiln insulation and an esbit burner in the lid. Fits nicely in a pocket stove Ti for a very compact multi fuel stove that fits inside a mug
- TheBrownDog
Yep they're pretty basic. This one was ok. 40ml of meths managed to get 750ml boiling twice and then came very close to a third before it puttered out. What it didnt do was burn clean - the mug was covered in soot so its clearly not burning clean, either the width of the tin or the 5 year old carbon felt I stuffed into it is the culprit. I might try again with some roofing insulation and packed it in with some mesh and see what I get. In the meantime the one that came with the cone will do nicely.
A set of poles for my TrAliStar, a bottle to keep meths in, and a sticker to tell me that I need to actually get out and use these things.
Cheers Stu!
Cheers Stu!
I bloody hate the Chainring bolts some manufacturers use - Cheap alloy and torx don't mix for me - why do we the need for change just for the sake of it. Give me stainless and hex everytime - always done me well in the pastMart wrote:a little wonky ring to go on my shorter cranks. Let the experiment continue
Now sourced something proper!......Rant over - As you were folks
Two pedal spanners for travelling... both of which I had hoped would be lightweight. Neither of which actually are.
I think I'm just going to have to get some pedals that go on with Allen keys and use them for any such trips.
Porcelain Rocket Albert.
SMD Deschutes Solo.
SMD Deschutes Solo.
a couple of Ortlieb panniers, which are a vast improvement from my aldi/lidl ones
Arrived yesterday at my wife's work so only at home today: Hollowtech 2 bottom bracket; a SRAM crankset; 10spd chain; 10spd derailleur; set of shifters; gear cables. Coming in the next day or so a new back wheel.
I might have a bit of work on the way
I see a problem here...whitestone wrote:Hollowtech 2 bottom bracket; a SRAM crankset;
Hope BB adapter The SRAM GXP bottom bracket doesn't have a good reputation.Zippy wrote:I see a problem here...whitestone wrote:Hollowtech 2 bottom bracket; a SRAM crankset;
As far as I could work out SRAM only seem to make 2 threaded BB's, a bottom spec one RRP about £30 and a ceramic one RRP about £170.whitestone wrote: Hope BB adapter The SRAM GXP bottom bracket doesn't have a good reputation.
My experience of the cheap ones in MTBs is they don't last very long at all. I've had no issues using Hope ones with the adaptors.
I've got the cheap one in my road bike (came with it) and I have bought a ceramic Hope one from the classifieds to replace it as it was making a noise... not yet fitted as the noise turned out to be the seat post The SRAM one has now covered over 2000 miles in all weathers without issue but it never sees any mud.
Greg, Deschutes from where?GregMay wrote:Porcelain Rocket Albert.
SMD Deschutes Solo.
Postie wasn't around but I went to built up my new bike with the companies mechanic. Proud owner of a geeked out Bold Linkin Trail LT.
A 29er 160/154 mm überbike for the Alps. It's got good space for a frame bag too
This lot's going on my commuter so it's just going to be general road grime with a bit of mud from the canal towpath.sean_iow wrote:As far as I could work out SRAM only seem to make 2 threaded BB's, a bottom spec one RRP about £30 and a ceramic one RRP about £170.whitestone wrote: Hope BB adapter The SRAM GXP bottom bracket doesn't have a good reputation.
Some smaller drinks bottles. Ideally I'd end up with one sub 500ml, but no-one seems to sell them (there is one, but it needs a different cage).
I really just carry water for emergencies these days, but I can't get to the point where I'm willing to ride with none.
In that case it should last forever, I had assumed this was the parts you'd wore out on the HT550whitestone wrote:This lot's going on my commuter so it's just going to be general road grime with a bit of mud from the canal towpath.
The postman has just delivered my serviced Fox 32's back from TF Tuned, really impressed with their customer service. I'll be able to take the rigid's back off ready for my YD300 ITT mid July. As luck would have it I drove to work today as I had to go out to a meeting, easier than trying to carry the forks home under my arm riding the commuter, anyone would think I'd planned it that way
I was really pleased with TF Tuned last time I used them. Fork felt better than it did when I bought it new.
The only bits I wore out on the HT550 were the rear brake pads which given the amount of mud that kept building up on the caliper wasn't surprising. I gave the bike a good clean/lubricate the other night and everything else was fine.
Hope stainless steel BB with a Raceface crank on the Solaris.
Steel bowl and mug for the wife for when we have a day out with the kids involving food/fire/stove
Couple of insulated snood/hats for the kids for this xmas' trip to Lapland
HH dry full set of baselayers for my son, for Lapland
nothing for me, boo
nothing for me, boo
- ZeroDarkBivi
That certainly is a unique, special bike; would be very interested to know how you get on with it. I am tempted to buy a long travel bike for next year, but sticking to 650b wheels as I am a hobbit and already struggle with the short travel Spearfish 29er geometry. Also waiting to see how the now R3ACT suspension platform is received, as it might be the next genuine game changer in FS bikes.Alpinum wrote:
I've started a topic hereZeroDarkBivi wrote:That certainly is a unique, special bike; would be very interested to know how you get on with it. I am tempted to buy a long travel bike for next year, but sticking to 650b wheels as I am a hobbit and already struggle with the short travel Spearfish 29er geometry. Also waiting to see how the now R3ACT suspension platform is received, as it might be the next genuine game changer in FS bikes.Alpinum wrote:
http://bearbonesbikepacking.co.uk/phpBB ... 10&t=10235
for more on the bike and what I do with it etc.
The strap on my Brompton Game Bag broke, which I was pretty disappointed about considering it's not a cheap bag
Original retailer were disappointingly poor in sorting it as it was out of warranty, and were lame in reaching Brompton. So I skipped them and went straight to the manufacturer, Chapman bags.
They were most excellent, dropped it off in their London showroom (v near work). Was delivered to my house yesterday with a very professional fix. No postage charges which is a bonus
Had to use my Carradice SQR Slim in the meantime, which while perfectly fine, is less convenient than the Game Bag
