Neoair XLite vs Exped Syn UL7
Thoughts?
Neoair seema so noisy when you move around!
Re: Neoair XLite vs Exped Syn UL7
Exped for comfiness, thermorest for lightness.
My money would go on the exped.
Yep.flatfishy wrote:Exped for comfiness, thermorest for lightness.
I cant comment on the neoair but the Exped is great - amost as comfy as my bed!
- TheBrownDog
Im using the long/wide Syn UL7 and its very comfy and remarkably warm. Its also nice and quiet. I wish Id bought the size down though - the full size one is a bit overkill even for a lump like me. Inflating it is a faff. They recommend using one of their pillow pumps to avoid getting condensation inside the mat from your breath, and while it only takes 3-4 minutes doing so under a tarp in the rain is a right pain. Practice on your living room floor a few times before you use it in anger would by my advice. Otherwise, you cant go wrong.
Big fan of Exped mats. I don't think the weights are really comparable, a small Exped is 52cm x 163cm (pretty much full length), a small Neoair is 51cm x 119cm.
I use an Exped Schnozzle bag to blow them up, much faster than a pillow or mini pump.They recommend using one of their pillow pumps to avoid getting condensation inside the mat from your breath, and while it only takes 3-4 minutes doing so under a tarp in the rain is a right pain. Practice on your living room floor a few times before you use it in anger would by my advice. Otherwise, you cant go wrong.
At 66g this might be lighter than the surplus inflating dry bag I take with me for my neoair:
http://www.facewest.co.uk/Thermarest-Ne ... wwodTL8ANA
Going a smidge off topic.....
Would anyone buy a Hyalite AC Peak mat new if it was £35? I seem to recall they were less than reliable.....
I wouldn't if it were my only mat, although I might as a spare to loan out. The leaks always seemed to be around the valve area, I wonder if a good coat of seam sealer before use would help?Would anyone buy a Hyalite AC Peak mat new if it was £35? I seem to recall they were less than reliable.....
I had the previous version that was branded Pacific outdoor and got fed up repairing it. A lot of people had trouble with the air mats.johnnystorm wrote:Going a smidge off topic.....
I replaced it with the HYALITE Peak Oyl Lite which is a self inflating which has been great for me so far but only had about 6 nights on it. There doesn't appear to be the issues with they self inflating mats that there were with the air mats.
Only £30 on sale at the moment at Blacks. http://www.blacks.co.uk/equipment/11648 ... -long.html
Cheers. I was idly looking at something in between my Klymit & Xtherm. Palm Oil petite looks a good compromise and is £25.
I sometimes wonder if you could pump up mats with your bike pump - with an adaptor I guess, but since I will have the pump with me anyway...johnnystorm wrote:At 66g this might be lighter than the surplus inflating dry bag I take with me for my neoair:
I like that battery powered one though :D
I reckon it'd take a long time, a mat requires air volume and bike pumps are more about pressure.I sometimes wonder if you could pump up mats with your bike pump - with an adaptor I guess, but since I will have the pump with me anyway...
Yeah, I looked it up I just feel that it should work... Hmm how much is in those C02 canisters...
Enough to make your mattress nice and frosty!Yorlin wrote:Yeah, I looked it up I just feel that it should work... Hmm how much is in those C02 canisters...
Hmm! I can just heat the cartridge over my ultralight stove...
If you do heat your canister over your stove, could you film it please
For my exped syn mat, I've never used anything other than my gob / lungs to inflate it and I've not died yet
