FS: Wild Country Zephyros Compact 1 tent
errol
Post by errol »
New and unused. Wild Country Zephyros Compact 1 tent. Bought with intention of using for BAM but have stuck with the tarp and bivy bag. Never been removed from bag 30 x 18 packed.
£120 posted.
Bit of blurb,
► Suitable for 3 season use, wild camping and campsite trips.
► The Zephyros Compact 1 tent pitches as one (the flysheet and inner pitch together) for speed and simplicity, it’s even quicker to peg out with new combined flysheet and inner pegging points.
► A new side opening tarp style bag makes it easier to pack away when it’s time to move on – simply roll the tent into the bag and pull the drawcord tight.
► It's based on the tried and tested Terra Nova Laser Competition design. Its low profile shape helps with its stability in poor weather.
► The lightweight tent comes with a Superflex alloy main pole which folds down to 30cm long, and folding Superflex alloy end poles and alloy ‘v’ angle pegs for a secure pitch.
► The high-performance polyester flysheet and groundsheet are fully seam-sealed for waterproof protection and the inner has a door that is half midge-proof mesh with a small mesh panel at each end of the inner tent to help with ventilation.
► The guylines and pole sleeve trims are reflective for better visibility when you return to your tent in poor light or dark conditions
PM for pics as not had much success trying to get them to show on here. :shock:
Tks
