FS: Bird forks, disc rotors
slackman99
Post by slackman99 »
Having a general clearout.
Happy to do something on price if you want multiple items.
Genesis Tarn frame
Size large
Boost rear, 27.5+ but also takes 29x2.6 so gives you the choice of either. Tapered head tube
Good condition, with a few paint chips and light scuffs from use
Complete with headset, seat clamp and rear axle
SOLD
Fox 34 Float Rhythm 130mm 29″ boost
51mm offset, 205mm tapered steerer with star nut fitted.
In good condition with little use as they’ve been on my second bike. A couple of minor chips at the bottom of the lowers and one on the underside of the brace.
No marks on the stantions.
SOLD
Bird Blank boost rigid steel forks
Good condition, complete with axle. A few scuffs but no large chips or scratches.
505mm a/c so properly suspension corrected
205mm steerer with star nut installed
£70ono
On One Mike bar
Was on my daughters bike for a few months so very little use
SOLD
Tektro cable disc brakes and levers
SOLD
2x Monkii Cage + clips
SOLD
Disc rotors
Formula 203mm 6 bolt - used - £10
Formula 180mm 6 bolt - used - £10
Avid centreline 6 bolt - new - SOLD
Brand X Ascend Dropper 31.6mm 125mm drop
Used but good condition save for a scratch to the part that inserts into the seattube (i.e., not the stantion)
SOLD
Tyres
29x2.6 Nobby Nic Pacestar Evo TLE - little use, with tubeless residue - £15
27.5x3.8 Minion FBR - little use, with tubeless residue - £20
Kingroon KP3S Pro V2 3d printer
Very little use so in very good condition, just surplus to requirements :)
Also compact for the build volume of 200x200x200
There are various different versions of this printer. This is the latest top spec version with
Linear rails on all axes,
Klipper so you can control the printer from a web browser as well as from the printer,
Direct drive with all metal hot end and ceramic heater block
Removable PEI spring steel build plate
Canbus connection
Review here as a example but there are plenty more
https://www.youtube.com/watch?v=CAveiv7UUCo
Only modification was to add some under bed insulation.
Ideally I would prefer it collecting, but may be able to meet up depending on location or could possibly find a box and post at cost.
SOLD
gecko76
Re: FS: Clearout inc frame, forks, tyres, dropper, discs
Post by gecko76 »
Can I take the monkii cages/clips?
slackman99
Yep, drop me a pm
javatime
Post by javatime »
Will pm you re dropper and nobby nic
sqibjib
Post by sqibjib »
Pmd you 😁
Life is better on a bike
