SOLD!
Specialist Hoprocker
SOLD!
Alpkit Woodsmoke (SOLD) - £35 posted (£30 collect from GU10)
SRAM RIVAL 22 hydraulic 2x11 shifters and calipers. - £250 posted for pair (£240 collect from GU10)
Bought these for a new bike build which never happened. They're brand new never fitted.
Very similar to these: https://www.wiggle.co.uk/sram-rival-22- ... ku=444850
Spec:
SRAM Rival HRD Hydraulic Disc Brake Caliper Shifter Front Brake - Right Rear Shifter 900mm 20PP
SRAM Rival HRD Hydraulic Disc Brake Caliper Shifter Rear Brake - Left Front Shifter 1900mm 20PP
NOTE: the calipers are for post mount which means they will fit flat mount, post mount, or IS frames/forks with the correct adapters. I have two flatmount adapters I'm selling below if required.
Putting them on here before i ebay them as the postmount ones are like hen's teeth!! Perfect for older frames and forks.
TRP post to flat mount adapters 160mm - £20 (pair) posted or £10 each). Brand new unopened!
Pics here: https://photos.app.goo.gl/uoHbVyTT3Djwnk596
If you can't see them on the link above then let me know please!!
Last edited by Specialist Hoprocker on Mon Apr 24, 2023 11:41 am, edited 4 times in total.
Re: Alpkit Woodsmoke shirt (L), SRAM RIVAL 22 hydraulic shifters + calipers
Shirt please, I'll drop you a pm.
Shirt now sold.
HUX
Post by HUX »
Ygm
