I've got two perfectly good Gore Waterproofs with knackered zips that need replacing
Can anyone recommend a repairer that they've used?
Zip Repair
- Dave Barter
Zip Repair
Re: Zip Repair
Scottish Mountain Gear are the folks often recommended, although I haven't used them personally
Re: Zip Repair
Have you tried the zipper-adjustment thingy Dave?
https://www.youtube.com/watch?v=pND6-omqt4k
If the actual hooks are worn & the whole zipper wants replacing then there's also Lancashire Sports Repairs to add to Bens reccomendation..
https://lancashiresportsrepairs.co.uk/
I haven't used them personally, but i'm sure they sorted one of Nordy's old gimp masks for him
- Dave Barter
Re: Zip Repair
The zips are properly fecked, my fault for using the waterproofs on the sea and the salt has done the damage. I thought Nordy's gimp mask came with a warranty attached to his entire dungeon?Wotsits wrote: ↑Mon Oct 31, 2022 12:25 pm Have you tried the zipper-adjustment thingy Dave?
Re: Zip Repair
Dave Barter wrote: ↑Mon Oct 31, 2022 1:55 pm The zips are properly fecked, my fault for using the waterproofs on the sea and the salt has done the damage. I thought Nordy's gimp mask came with a warranty attached to his entire dungeon?
Think he may of had a similar experiance to you Dave, in that he said the warranty didn't cover wear due to salty fluids
Re: Zip Repair
Genuine LOL moment there
Re: Zip Repair
Many of the Alpkit stores have a repair station in them, they repaired a bikepacking bag for me after a mouse chewed a hole i it and did an excellent job. If you don't have a store near you I'm sure you could post it?
Re: Zip Repair
Alpkit did a great job of popping a new zip in my wingnut bag. Just sent some photos for a quote then posted it off to them. Hope that helps a bit Dave.
Re: Zip Repair
If the zip coil/teeth are plastic and it's just the slider that's corroded, it's pretty easy to replace the slider yourself, it you can identify the type of slider used, most are available on eBay for a couple of quid.Dave Barter wrote: ↑Mon Oct 31, 2022 1:55 pm
