Wanted - Rigid Fork for MTB
After some rigid forks for a drop bar mtb project.
Budget is small (should really be buying new discs and pads for the van not building a bike) so probably something steel/alloy?
Along the lines of a Salsa Firestarter, Genesis Longitude or Sonder Frontier? Cage mounts would be nice in case it works well and I decide to take it further than the commute.
Disc brake essential and post mount preferred. Cosmetic condition and colour not important as I can always re-finish them if necessary.
Re: Wanted - Rigid Fork for MTB
I'll have a look. Couple of pairs of Salsa hung up but I'll need to check what they are.
On one carbon 100mm and QR
Postage + a tenner which will go on the bear ( PM if any use )
I probably should have mentioned the wheel size, the frame is 650b and designed for a 100mm to 120mm fork.
I previously had a suspension corrected 29er fork and it seemed to be fine.
Don't know if this affects any of the replies above.
Its in the attic I will measure A-C* but i assume its for 100mm
Alexpalacefan
Post by Alexpalacefan »
Hi, if the OP doesn't want the fork Lazarus I'm interested.
alexb1636@yahoo.co.uk
Cheers,
Alex 🙂
Dyffers
Post by Dyffers »
Lazarus wrote: Wed Oct 26, 2022 3:54 pm On one carbon 100mm and QR
Longshot but if this turns out to be for a 26er and no good for Sean or Alex I'm interested as a way to lighten my son's XS Inbred currently running an On One 420 or 440 (I forget) A-C heavyweight steel fork.
29 ers and 480 A-C
FWIW my 26 er Rebas were the dame A-C I rode it with 26 er wheels but it is a 29 er
