Just finalizing my WRT route.
Is there a way from Cwmystwyth or The Arch to Eisteddfa gurig through the forestry?
(The green dotted path from Ponterwyd towards Eisteddfa Gurig seems to run out at SN 794 826 which seems a bit odd) I was hoping to come down the hill onto this path
Do You know... [Route advice]
Re: Do You know... [Route advice]
Weave your way through the forest from the Arch and head for the track which leaves the NE corner of the forest at SN 807804. It's a steep push up the head of the valley but it's pretty quick / direct.s there a way from Cwmystwyth or The Arch to Eisteddfa gurig through the forestry?
Thanks Stu. I shall try it out
