USB-powered AA battery charger
Asposium
Post by Asposium »
As many here I use an AA-powered Garmin hiking type GPS for bikepacking.
Fine for short (long weekend trips) when I usually take a few sets of spare rechargeable batteries.
I appreciate LiON batteries last longer; however, I am a tight arse Northerner. :lol: :lol:
So, been looking a small, lightweight, USB powered, smart AA charger.
Have found one.
Sharing here is others might find useful.
Not much larger than an AA battery case.
Powered via micro-USB, will run from a standard battery pack.
https://uk.gpbatteries.com/products/gp- ... yko-pro-aa
Re: USB-powered AA battery charger
I have a cheap ikea one. Charges 2 AAA or AA cells at a time, not sure on specs but it seems to work well enough
javatime
Post by javatime »
Think you can run the Garmin directly from a USB cable from a Powerbank
Need to select Garmin mode instead of USB / Storage
Maybe just Etrex30
I will await either confirmation from the forum, or to be corrected.
Asposium
Post by Asposium »
javatime wrote: Thu Apr 07, 2022 5:11 pm Think you can run the Garmin directly from a USB cable from a Powerbank
Maybe just Etrex30
One can, appreciate that.
And I killed a Garmin doing just that.
So this is a heads up to those that want to run off AA's and need a way to recharge during the ride.
Chrisps
Post by Chrisps »
That's a nice little unit. I am slightly suspicious of their charge times though... My mains Nimh smart charger takes far longer to recharge batteries than that.
One other point, don't assume Lion is expensive... the Xtar Pb2s 18650 Lion USB smart charger is only £16ish and 18650s aren't that expensive. Then you can use it as a power bank too. But that certainly looks useful for AA use cases... Thanks for sharing :-bd
I use these high powered ones that can charge from your powerbank overnight
https://www.amazon.co.uk/gp/product/B08 ... UTF8&psc=1
EBL 1.5V Lithium AA Rechargeable Batteries 3300mWh
javatime
Post by javatime »
Thanks for that, worth knowing!
ripio
Post by ripio »
I got this set of rechargeable lithium batteries plus charger last year.
https://www.amazon.co.uk/Kratax-3500mWh ... 727&sr=8-4
Get about double the run time in my Garmin Dakota 20 as I got with rechargeable NiMH batteries.
But not as long a run time as with non rechargeable lithium AA batteries.
godivatrailrider
Post by godivatrailrider »
Eneloops for me ... https://www.batterystation.co.uk/panaso ... es-4-pack/
A pair will run my Garmin Oregon 450 for 2 days, so taking a spare pair will do 4 days.
But maybe a charger works better for some.
Asposium
Post by Asposium »
godivatrailrider wrote: Fri Apr 08, 2022 9:53 am Eneloops for me ... https://www.batterystation.co.uk/panaso ... es-4-pack/
I have those exact same batteries.
Get ~ a day in an Oregon 700 with the unit in "power saving"; low screen brightness, BT turned off, etc.
I'm going to Iceland hiking for a week, and a mutli-week bikepacking trip, so need an easy and convenient means to recharge the AA's from a USB battery pack.
This charger seemed ideal
JohnClimber wrote: Thu Apr 07, 2022 9:52 pm I use these high powered ones that can charge from your powerbank overnight
I have those too. Handy for convenience but not actually high powered. They're the only brand I know to use mWh rather than mAh and that's (deliberately?) confusing.
Asposium
Post by Asposium »
ScotRoutes wrote: Fri Apr 08, 2022 10:02 am
i saw the rechargeable LiON batteries and thought they could be ideal
direct charge, and no charger needed.
then read some of the reviews. :lol: :lol: :shock:
