Inner Tubes
Inner Tubes
I've just binned an inner tube with 18 patches, which is something of a record for me . Anyone have one with more, or managed to "join the dots" around the entire tube?
Does anyone else still use tubes or am I just stuck, hopelessly, in a bygone era (along with my 26" wheels)?
Re: Inner Tubes
Plainly, Pete, you already knew that this thread would end up with precisely two posts on it. Yours and mine .
18? I'm pretty sure I was into double figures on Rude Place Names, but no, I cede to your rubbery magnificence. Well played Sir!
If I'm ever in urgent need of a rubber leakage (which always occur at the most embarrassing moments obviously) preventive in the future I'll know where to, er, come.
Re: Inner Tubes
Still on tubes, but I've not reached 18 patches before, never mind joining the dots
Not sure my record, maybe a measly 8?
I did have a mild panic the other day riding down a lane where I suddenly saw the gorse hedge had been recently flailed, so I had a very wary few hundred metres with thoughts of maybe I should try tubeless.
Now living back in the land of flailed hawthorn and gorse I may have to bite the bullet
- TheBrownDog
Re: Inner Tubes
I ran out of patches one day after riding about a couple of miles of bridal path that just had the hawthorn cut. Six flats IIRC. I even got a flat pushing the bike the last few yards. That was it for me and tubes, though the hassles I've had from time to time with tubeless has me longing for a half-way house of some sort.Moder-dye wrote: ↑Mon Dec 27, 2021 2:53 pm I did have a mild panic the other day riding down a lane where I suddenly saw the gorse hedge had been recently flailed, so I had a very wary few hundred metres with thoughts of maybe I should try tubeless.
Pete: 18 patches is brilliant. Way to save the planet and money at the same time. Chapeau chap.
Re: Inner Tubes
Still tubes on the road tyres. I might change that when they need replacing.
FWIW I'm pretty sure I've not had 18 punctures in all the years I've been riding bikes. And I do mean in total.
Re: Inner Tubes
Cheers gents .
I've always aspired to some sort of magnificence, so...
...sounds like the very best kind .
- ledburner
Re: Inner Tubes
I have just passed on my 26 inner tubes to a bike recycle charity. You can have first dibs on little usedmtb tyres before i pass them on aswell, Conti summat speed or race KingsMuddyPete wrote: ↑Mon Dec 27, 2021 1:19 pm I've just binned an inner tube with 18 patches, which is something of a record for me . Anyone have one with more, or managed to "join the dots" around the entire tube?
Re: Inner Tubes
Thanks for the offer LB, but I've treated the bike to a new tube and normal service has resumed .
- BigdummySteve
Re: Inner Tubes
Arhhhh (g) I remember tubes, bloody horrible things. I think it’s just you and Reg left.
I think my record was 14 punctures on one ride just after they cut the hedges on the cut.
Re: Inner Tubes
I usually rip the valve out long before I run out of of space to put patches on... Still with tubes on the 700 by 40 or less as tubeless only works on such sizes at less than 45psi and I tend to run them at 55 - 65psi due to needing to go really really fast Funnily enough I've been plagued with thorn punctures recently, all on my otherwise fab Conti speed rides
Re: Inner Tubes
That confetti can be bloody sharpI ran out of patches one day after riding about a couple of miles of bridal path
- TheBrownDog
Re: Inner Tubes
That's one of my regular typos. I can get pretty messy with they're their there too.pistonbroke wrote: ↑Mon Dec 27, 2021 11:33 pmThat confetti can be bloody sharpI ran out of patches one day after riding about a couple of miles of bridal path
- ledburner
Re: Inner Tubes
Its not just me thenTheBrownDog wrote: ↑Tue Dec 28, 2021 9:35 amThat's one of my regular typos. I can get pretty messy with they're their there too.pistonbroke wrote: ↑Mon Dec 27, 2021 11:33 pmThat confetti can be bloody sharpI ran out of patches one day after riding about a couple of miles of bridal path
So the bridleways go anywhere, but round here they lead to dead ends or footpaths.
The Bridal paths end up at the registars, eventually. If you also suggest thats a dead end you'll also discover the proverbial deep hole.....
Just keep on digging...
Re: Inner Tubes
I not ran tubes for over 10 years thus saving myself a lot of dosh, plus not having to carry spares save a lot of dead weight. Also I can run lower psi to give a smother ride.
Re: Inner Tubes
That’s some impressive patching.
Think most I have ever had was around 10 then it normally get a cut up and used as a new chainstay protector.
Finding it harder to get my 26inch tubes and tyres which is another reason to patch them.
Re: Inner Tubes
I was wandering how long it would take 'till the tubeless party (one myself) joins in with the obvious (it's better etc.).
I'm writing that because I was very close to doing just that myself
But it to stick with the topic;
My record is 13 plugs in one tyre (in about 4 months).
I can't blame the tyre though. My bad in riding mistakes, mostly when trying to go fast (bad line choices, braking in thr wrong places etc.). Good thing is, it usually just takes me a minute or two to put a plug in and pump it up.
