Size M/L Basically arm warmers for running but you could just as easily wear them riding.
https://montane.com/collections/mens-tr ... -armguards
Bought a couple of weeks back, tried them on sat on the sofa, thought they fitted, took the tags off and wore them on the run to work. Due to having puny arms they slipped down. Washed and then I stitched the top to make them smaller. Wore on another run but they are still a bit big. Washed again and not used since. I could stitch them tighter but it's getting silly now. I emailed Montane who sent me the dimensions of the next size down (XS/S) which would still be too big. Either I've got very thin arms or they've got the sizing wrong. Runners aren't known for their biceps so I'm guessing they've messed up here.
Dimensions - from Montane
Full Length - 45cm
Bicep Opening Width(relaxed) - 26.5cm
Bicep Stretch Measurment - 40.5cm
Half Sleeve Circumference - 23.5cm
Wrist Opening Width(relaxed) - 16cm
I'm not going to use them so they need a new home. £12 posted. I can unpick the stitching or leave it in if preferred.
Montane Trail Armguards
