Software for editing gpx files
mikejd
Post by mikejd »
Hi guys,
I'm looking for a website that I can upload gpx files to then edit them. I think I used to be able to do this with gpsies.com but that is no longer available. I want to be able to split a gpx file and join with another. I know this is technically possible by editing the xml code in the file but I'd rather have a visual interface.
Re: Software for editing gpx files
Garmin Basecamp if you're happy with using a program rather than a website.
mikejd
Post by mikejd »
@scotroutes
Thanks for the suggestion. slight difficulty is that I don't normally use Windows. My desktop and laptop do dual boot Linux/Windows but I haven't used Windows for years. If I don't find something else I could try this.
Try https://gpxstudio.github.io/ and see how you get on.
mikejd
Post by mikejd »
@K1100T
Had a quick look at that. Looks promising for what I'm looking for. A bit of practice and I think I can use it. Thanks
K1100T wrote: Mon Jun 07, 2021 8:11 pm Try https://gpxstudio.github.io/ and see how you get on.
This looks brilliant! Have been looking for a free replacement for gpxeditor.co.uk which does a lot of the same stuff, but requires a subscription for the useful stuff (multiple tracks, OS maps) now. Cheers
I've only used it the once, when I needed to stitch two GPX track files and a GPX Waypoint file together. I normally just stick everything into RideWithGPS, but features like that are paid for, which is how I stumbled across it. Let's us know how you get on with it...
mikejd
Post by mikejd »
@K1100T
I am trying to build a gpx file for a long route from bits of other rides. In gpxstudio I can upload individual files and crop out the sections I need and can open multiple tracks at the same time. Haven't quite got the hang of merging these into one track yet, but, hopefully, just a question of practice.
K1100T wrote: Tue Jun 08, 2021 10:57 am I've only used it the once, when I needed to stitch two GPX track files and a GPX Waypoint file together. I normally just stick everything into RideWithGPS, but features like that are paid for, which is how I stumbled across it. Let's us know how you get on with it...
The "+" button on the toolbar on the left allows you to merge tracks. Select one track "tab" at the bottom, click "+", click the other track tab.
mikejd
Post by mikejd »
Thanks @thenorthwind
belugabob
Post by belugabob »
If you are using a Garmin device to provide turn-by-turn instructions, you need to be wary of creating a route that exceeds the number of waypoints that your device supports, per route.
For my Etrex 35, it's 40, so longer, or fiddlier, routes usually have to be split up.
Name each route in sequence (Dales1,Dales2 etc) and they should be easy to find, as you finish each stage
