Middleburn RS8-X Cranks, 24mm axle, 175mm length.
Have a bit of "patina" as you can see, but functionally are spot on - nothing threaded or missing. You just put them on and forget about them.
There's a 30t Uno ring, but it's pretty worn - doesn't hold the chain very well over the rough stuff. Think of it as you're buying the cranks and it's a freebie
£75 posted with special delivery
Re: Middleburn RS8-X Cranks, 24mm axle, 175mm length.
Hello, popped you a message on STW, keen on these as a winter polishing project
