Sleeping bag or quilt with tiny pack size
ChrisS
Post by ChrisS »
As part of my project to get my entire sleep kit (including bivy, tarp + mat) into an 8l dry bag, I'm looking for a summer bag that packs really small. My current bag is an Alpkit Pipedream 400 which is too warm for summer and doesn't compress nearly small enough.
Compressing to a tiny size is more important than weight in this case, though I realise the two tend to go together :smile:
The bivy bag, mat and tarp take up about half the space in the 8l dry bag, maybe a bit more, so I need something that packs down to 4l or smaller, if that's possible
Never used a quilt, but willing to give one a go. What's out there? I guess the Cumulus 150 would be a top contender if it packs small enough.
The Cumbrian
Re: Sleeping bag or quilt with tiny pack size
Post by The Cumbrian »
I've got a Sea to Summit Traveller TR1 Long sleeping bag / quilt, and I managed to squeeze it, a 3/4 length underquilt, a down jacket, my sleeping base layers, a hat and a pair of warm socks into a 9l handlebar drybag.
Bilbo Baggins.
Cumulus 150 would be the choice du forum but if you are a cold sleeper then the 250 might be better. Also consider high quality sleeping bags like PHD, their Minim 200 packs small.
I can easily get the Cumulus 150, Exped May, Borah Gear bivy, Trekkertent DCF tarp into an 8L bag. If I used the Klymit X-frame mat then I could probably get that lot into a 5L bag. Pole and pegs would be elsewhere just to avoid abrasion.
I'm with Bob. The 150 quilt packs to nothing, weighs little and is surprisingly warm.
ChrisS
Post by ChrisS »
The Cumbrian wrote: Tue Jul 28, 2020 12:06 pm I've got a Sea to Summit Traveller TR1 Long sleeping bag / quilt, and I managed to squeeze it, a 3/4 length underquilt, a down jacket, my sleeping base layers, a hat and a pair of warm socks into a 9l handlebar drybag.
Not come across the Sea to Summit bags before, will have a look. That's a lot of kit in a small bag!
ChrisS
Post by ChrisS »
whitestone wrote: Tue Jul 28, 2020 12:07 pm Cumulus 150 would be the choice du forum but if you are a cold sleeper then the 250 might be better. Also consider high quality sleeping bags like PHD, their Minim 200 packs small.
PHD Minim 200 is lovely, but spendy. I almost bought a used Minim earlier this year for a great price but it was one of the warmer models. Packed down incredibly small though.
I've been packing pegs with the tarp and hadn't thought about abrasion... New pole hopefully arriving from Stuart this week :-bd
I have a Cumulus 200 bag (like the 150 quilt) and it just squeezes into a 1 litre drybag, but you can't close the drybag. With a Klymit inertia X frame small mat, a Borah bivvy all rolled up it easily fits into a 5L bag. You could get away with this, but it is minimalist. I also tend to pack a polycro sheet and a couple of spare bits of clothing (leggings and a base layer top) to help keep the bag/bivvy clean and dry and it all easily fits into an 8L bag.
ChrisS
Post by ChrisS »
slarge wrote: Tue Jul 28, 2020 12:27 pm I have a Cumulus 200 bag (like the 150 quilt) and it just squeezes into a 1 litre drybag, but you can't close the drybag.
That's really useful to know thanks - looks a good bag and should easily fit into the space I've got with room for a layer too.
I use a slightly beefier mat. I've tried a Klymit but don't get much sleep on one!
ChrisS
Post by ChrisS »
Bearbonesnorm wrote: Tue Jul 28, 2020 12:11 pm I'm with Bob. The 150 quilt packs to nothing, weighs little and is surprisingly warm.
Cheers :-bd
^ Take note of this. I'm obviously a cold sleeper as I find my 150 only just about warm enough even in mid-summer and most of the time I end up wearing a lightweight synthetic jacket as well. The 150 packs easily into a 3L dry bag so is tiny. I don't think the 250 takes up much more space.
The 250 weighs 110g more but 100g of that is extra down, so for the 110g you get 66% more down that you will in a 150. If I was to buy again for actual 'sleeping' I'd get a 250. For a few hours shivering mid race, for me the 150 is ideal :grin:
Chew
Post by Chew »
I can get a 250 cumulus quilt, mat, alpkit hunker XL, buff, t-shirt & boxers, plus hipster down gillet into a 8 litre dry bag.
Its a squeeze, but it all fits :-bd
ChrisS
Post by ChrisS »
sean_iow wrote: Tue Jul 28, 2020 12:49 pm
Noted. I do sleep cold so 250 may be a better option.
My Cumulus 250 quilt easily fits in a 4L Sea to Summit drybag.
I've been tempted by a 150 as I'm a warm sleeper but Highland Scotland rules out all but a handful of suitable nights each year.
Scud
Post by Scud »
I have a Mountain Equipment Phantom Spark down bag, rated to -2, which with my Rab Superlight bivvy bag (not the smallest at all, but is Event and has attachment on top for a line so it holds mouth of bag open and away from face) and Neoair mat all fits inside an 8l bag including Exped inflatable pillow and merino long johns.
https://www.mountainhardwear.com/phanto ... 71441.html
ChrisS
Post by ChrisS »
ScotRoutes wrote: Tue Jul 28, 2020 1:54 pm My Cumulus 250 quilt easily fits in a 4L Sea to Summit drybag.
As all of my bikepacking is in Scotland, the 250 is looking like a good choice, if I could find it in stock anywhere 👀
One point to note - keeping all of your bivy gear in the same bag isn't necessarily a good idea - what happens when your tarp and bivy are wet? You can get round this by using a dual compartment dry bag but most on here will use one dry bag for stuff that has to stay dry and one for the potentially wet items.
ChrisS
Post by ChrisS »
whitestone wrote: Tue Jul 28, 2020 7:36 pm One point to note - keeping all of your bivy gear in the same bag isn't necessarily a good idea - what happens when your tarp and bivy are wet? You can get round this by using a dual compartment dry bag but most on here will use one dry bag for stuff that has to stay dry and one for the potentially wet items.
I tend to stuff the sleeping bag in loose and put the tarp in a small dry bag if it's wet, or there's usually a bit of room in my seatbag. AFAIK Wildcat were the only folk who made a dual compartment dry bag and it's on my list if/when they start up again.
mattpage
Post by mattpage »
I have a PHD autumn race bag.
No longer made, but a form of the minim I think. It is a light bag, but a different outer than I seem to remember was thinner/lighter, but downside is some down comes out from time to time.
But it is 336g without a stuff sack. 353g with the standard one, although I use a smaller, lighter one as it packs down so small.
Comfort down to 7, but I have used it to 1 degree when the temperature plummeted when not forecast.
Brilliant bag and while its no longer made, PHD as a brand are brilliant.
I have a PHD 1000FP quilt with a lower leg box / bag, like a half-half, it's under 250g I think and good down to about 7-8 degrees if I have a thin insulated jacket on. I can get that, a short Neoair and a Decathlon pillow into a 4l drybag with ease. It packs even smaller than my Minim Ultra but isn't quite as warm overall - it's close though.
Now, unlike Sean, I'm from the north and I've taken me 150 down to just above zero with a good mat and a fluffy ferret. I can't say that I was toasty but I was warm enough with the addition of a light down jacket that I could get a reasonable amount of sleep.
stevewaters
Post by stevewaters »
I suspect a 150 quilt with down jacket - particularly if hooded - is a warmer combo than a 250 quilt on its own.
I have the latter, but am considering the former too to have more flexibility.
The lightest hooded down jacket I can find is 218g and pricey (see link below). Less expensive options are heavier.
https://www.ultralightoutdoorgear.co.uk ... top-p12465
Bearbonesnorm wrote: Wed Jul 29, 2020 2:58 pm Now, unlike Sean, I'm from the north and I've taken me 150 down to just above zero with a good mat and a fluffy ferret.
I think I have been under-matted at times which hasn't helped. On my Neoair xlite I'm much warmer than on the Klymit X frame. I also don't take a ferret :grin:
stevewaters wrote: Wed Jul 29, 2020 3:11 pm I suspect a 150 quilt with down jacket - particularly if hooded - is a warmer combo than a 250 quilt on its own.
And a 250 with hooded jacket will be warmer still :smile: I used to obsess over the grams, the 2019 HT550 taught me that there is more to kit choice than just weight :smile: Let's not forget that the difference in weight between a 150 and 250 quilt is the same as 1 inch of water in a standard size bottle.
That jacket is very nice though. I was after a hooded jacket as my current one doesn't have a hood, but I've decided that I'll stick with my synthetic hood-less one. I sometimes wear it riding and the hood would only be flapping about and annoying me as it would be too hot under a helmet. For sleeping in cold weather I have one of these for my head
https://www.montane.co.uk/mens-c1/prism ... %5B3%5D=64
Oex Xenon Ultra is a 217 gram down jacket. I love mine!!
(it's the one in MattPages video of his around Wales trip)
And a lot cheaper than £200, if you can find one - I think they may have stopped making them now
slarge wrote: Wed Jul 29, 2020 3:32 pm Oex Xenon Ultra is a 217 gram down jacket. I love mine!!
I'd spotted them, I think John Climber has one as well. But they do appear to have stopped making them :sad:
Nah, £125 for a hooded MH Ghost Whisperer Mk2 at 219g! https://www.wiggle.co.uk/mountain-hardw ... S-EALw_wcB
Not quite sure what's going on there because the Mk1 I've just bought from Wiggle without hood is 209g, and I thought the Mk2 was a lot (40g :wink: ) heavier than the Mk1. Bit cheesed off now 'cos might have had this if it had showed up when I got the Mk1. Arse! Still, I know that's Rule#1 of kit buying.
