Need some new wheels... what’s good?
Matt
Post by Matt »
The 29er front wheel Kev sold to me for £5 has given up!!
Suspect the warranty is gone
Need a new set of wheels for my Longitude
29
Both normal old school QR
Not XC lightweight, don’t need downhill super strong just summat in the middle
Hope hoops??
Re: Need some new wheels... what’s good?
Hunt getting a lot of fans
I like hope/stans but haven’t tried many others
Hope Hoops for me. I've broken one but that was my fault not the wheel's. I wouldn't use a tyre bigger than 2.35" on them as they are only 19mm internal width.
gairym
Post by gairym »
What about the rear wheel I sold you???
composite
Post by composite »
I'm not sure I will ever go with anything other than DT Swiss hubs these days. The ones I have had have been flawless for me. I have a couple of sets laced to light bicycle carbon rims, both MTB and road deep section and I really like them.
Matt
Post by Matt »
gairym wrote: Sun Apr 19, 2020 10:01 pm What about the rear wheel I sold you???
Still good 👍
But fancy a new pair 😀
Not like I’ve been a big spender so far
Unless you got the front to match 😀
gairym
Post by gairym »
Glad to hear it! :-bd
Actionsports de
Dt 350 hubs, dt butted spokes (or sapim d-lights if you're not too hefty), dt or stans rims, brass nips.
I also have a rear wheel in use with one of the funnworks xl25 rims, its absolutely fine.
Lots of custom options, sometimes cheaper than parts...
WTB i 23's, XT hubs and Sapim race or dt swiss comp spokes. Bomb proof and cheap.
XT hubs for me these days too.
In Reverse
Post by In Reverse »
htrider wrote: Sun Apr 19, 2020 10:27 pm WTB i 23's, XT hubs and Sapim race or dt swiss comp spokes. Bomb proof and cheap.
Excellent rims. Light and durable.
Matt
Post by Matt »
Found some XT wheels very cheap
Centre lock brakes though, I seemed to be very anti centrelock in my own head for no reason
Is there an actual problem with centrelock or should I just buy them??
Think £150 for a pair of XT wheels
https://www.bike-discount.de/en/buy/shi ... set-635925
What do you think is wrong with Centrelock? As someone who has worked as a bike mechanic I've never had a problem with them. I've seen loads of sheered/rounded rotor bolts though.
My wheels are about 50:50 but I'm favouring XT hubs these days.
The same as you, I've always been anti-centre lock but have no explanation why. I think it might be that I wouldn't carry the tool to take one off when on a ride, but I've never had to take a disc off when on the trail. I guess you might need to remove a disc to replace a broken spoke..... but I've never broken a spoke and I don't carry spares anyway.
You can get adapters to run 6 bolt if your preferred choice of disc isn't available as a centre lock version.
100kg max system weight doesn't seem very high
Hope Hoops for me. They used to use Stan's rims but they've now started doing their own and these are available in a variety of widths etc. I haven't used anything else (one set of Superstar wheels years ago) so its not a big sample size.
IIRC Shimano hubs used to be a bit weighty, wouldn't know if that is still the case. Also, are they still cup&cone? Personally I find that an unnecessary PITA compared to the simplicity of cartridge bearings, particularly if you're an "average" mechanic :wink:
Of course with Hope hubs you have the joy of their alloy freehub which tends to get chewed up and makes cassette "removal" interesting sometimes :wink: You can get a steel freehub if you specify it but of course that increases weight. Not an issue if you're running something which doesn't use that type of fitting.
From an engineering perspective, CL makes a lot of sense. I think the problem is that it's simply not what we're used to, hence the usual reservations. If it bothers you, buy some CL - 6 bolt adaptors.
Matt
Post by Matt »
PaulB2 wrote: Mon Apr 20, 2020 8:57 am 100kg max system weight doesn't seem very high
I would hope there’s a fair bit of tolerance in that!!
I've a couple of wheels fitted with CL rotors and have had no problem with them. Then again I've had no problem with 6 bolt rotors either.
The tool is just the normal Shimano cassette tool so most will already have it but of course it's a bit heavier and bulkier than a T25 driver if you are thinking of carrying one on the road but the NBT or Unior cassette tool might work as well.
One advantage if you are touring is that if you bent a rotor then you aren't limited to the 6 bolt design if the shop only has a CL rotor. (Unlikely)
Matt
Post by Matt »
Was just about to pull the trigger on those and a couple of adapters but not convinced...
Is 19c a bit narrow?
Is 100kg a bit light? (I weight 90kg)
I wouldn't even use 19c on a road bike these days :lol:
Leerowe76
Post by Leerowe76 »
benp1 wrote: Sun Apr 19, 2020 9:37 pm Hunt getting a lot of fans
https://www.huntbikewheels.com/products ... 1051233357
I have these fitted on my Big Bro.
Good build quality, look good and at £329 which is great compared to some other manufacturers and lighter than most at just under 1700g :-bd
at £329
You know he's from Yorkshire don't you. I assume the radio silence means he's still picking himself up off the floor after reading that figure. :wink:
Matt
Post by Matt »
:lol:
The bigger problem was a July lead time
Can’t ride my bike at moment as no spare wheel and Kev’s old wheel is toast.
Scattamah
Post by Scattamah »
Both my Bonty Mustangs and more recently DT Swiss Splines are centerlock. Even a three-thumbed monkey like me can't get 'em wrong. No problems in 6 years with 'em.
