Revo/Redeye input/output brain fart
After finishing a night shift this morning I connected my dynamo to the output port on my Revo and the Redeye to the input port. I only rode a few hundred meters but that looks enough to have damaged the Revo output electronics. The Revo still works but will no longer power the Redeye.
Has anyone else done this?
Are Exposure able to fix this, am I able to fix this - will be contacting them now to find out.
Re: Revo/Redeye input/output brain fart
Take comfort you aren't the first person to do this. I can't recall the exact details but I think that people usually have a decent outcome from exposure. It'd be better if they used different plugs to stop you being able to make the mistake.
Duplicate
I've done it.
Give exposure a call and tell them you're an idiot.
iirc they only charged me about £7 for the new resistor (or whatever it was) plus postage.
Emailed this morning and waiting for a reply. I like the sound of £7. My idiocy is usually more costly
I had this repair done by Exposure 2 weeks ago and it was £17. Normal turn around is apparently 5-6 working days. I asked if it was possible for it to be fast-tracked because I had plans to do a trip and they kindly obliged. They received it Thursday, I had it back Monday morning if memory serves.
My routine now is to always plug the rear in first, and watch for it to come on from the residual power that's in the Revo.
- NewRetroTom
My mate did it the evening before Paris Brest Paris this summer. Cost him 17 quid for the fix as above.
It did result in a bit of mild panic as we were thinking he didn't have a rear light for the ride. Then we realised we could put the red eye on my bike and plug it into my Strada and put my rear light on his bike.
The smart port connectors both being the same was both the cause of the problem and the solution.
Interestingly when the red eye was plugged into my Strada it was way brighter than it was plugged into a Revo (almost too bright).
a dynamo tends to only be able to do 3 watts [ and the front is taking the majority] so not that surprising it is brighter on a battery,
I did it about 10 days into the TDR. At night. Right as I was pulling onto a road. Suffice to say I pedalled very fast in the dark until Hartsall.
- Dave Barter
Having done it twice I put white cable ties on my dynamo lead to give an extra physical reminder.
Bit strange that exposure have not changed the design as they must realise how often it happens - Not bashing them as I rate their stuff.
Good idea Dave.Dave Barter wrote: ↑Sun Dec 08, 2019 9:25 pm Having done it twice I put white cable ties on my dynamo lead to give an extra physical reminder.
I just changed how I was mounting the light from right way up to upside down. That plus being addled from a lack of sleep didn’t help.
Think i’ll remake the connector with different coloured heat shrink.
The plus side is Exposure have been in touch already and the fixing process is under way. £17 all in is the current idiot tax.
better to have something you can feel[ zip tie on one and not the other for example] as you need to be able to do this in the dark
This is how I ended up doing it as well...lune ranger wrote: ↑Mon Dec 09, 2019 1:28 am I just changed how I was mounting the light from right way up to upside down. That plus being addled from a lack of sleep didn’t help.
Obviously a design oversight by them. I suspect it's a common mistake to make in the dark and/or when tired.
Surprised they haven't added some blocking diodes to prevent any accidental damage from misconnection. It wouldn't involve any external redesign to connectors.
Just saying....
Just saying....
Insanity over vanity
Got mine back on wednesday after sending it last Friday. Id snapped the lead - its a long story. On another occasion id plugged it in the wrong way round on the revo. (easily done in the dark so I've marked the redeye lead) Exposure fixed it then as well. They set a very high bar with their service and patience
still a shame they dont fix an obvious and know problem that is very easily fixable. Its not like having two diiferent connetors is a massive difficulty to do , you could even pre wire the light so you only have one port.
Dont get me wrongits great that they fix it, and yet they could/should realy fix it.
Still rate them and still going to keep using and raving about joysticks.
