MTB to Adventure bike
So next year were planning 2-3 adventures 2-3 nights away in the middle of nowhere. Couple of the guys buying gravel bikes but I've just bought a new road bike so this aint an option and I don't see a need to buy one. I do have an old MTB, GT Aggressor XC2, Rockshox Recon forks lockout, Shimano Deore group 44/32/22 & 10/32 cassette, hydro Discs, Alex DP17 rims (26"), Panracer fire xc pro 2.1" rubber.
So how can I make it more adventure bike than MTB.
Terrain will be Single trak, natural trails, forestry gravel roads, tarmac that resembles forestry roads and tarmac
Apart from the obvious luggage needed what else? type of tyres etc
Re: MTB to Adventure bike
To be honest, just ride it like that, it'll be fine
Change tyres if you want maybe
Bar ends?
1) what size tyres fit on the road bike that are suitable for the ride you re doing - fit them and ride that
2) buy cheap 26 er frame use that with all your bits - I think your overall time will be similar but you will be slow up and faster down so not that convenient for a group ride with Adventure bikes
3) ask to borrow one on classifieds
I really don't see what's wrong with what you already have ... adventure comes from the mind not from a brochure.
- In Reverse
Yep.
Schwalbe Big Apple tyres in 26" are a superb adventure tyre that should never puncture. Looks like you can pick them up for a tenner these days.
Maybe see if you can pick up a pair of touring (butterfly) bars for different hand positions? I'm a convert.
- BigdummySteve
You’re a very naughty boy
I’d not alter much from that except maybe tyres and bar ends.
I did amazing things on a 26er hardtail when that was the only bike I owned. I’d still be doing them now (probably) if my P7 frame didn’t snap.
- AndyTheBikeGuy
If there’s one thing the forum was missing it was an Only Connect theme. I’m on board.
Agree, nothing wrong with the bike you already have really.
Including the tyres!! I'm still running XC Pros and they're a great tyre OK, they may be a bit dated, things may have moved on and there's better rubber out there nowadays and a trend for bigger rubber but unless you want to spend money....
But the terrain hasn't really alteredthings may have moved on
I used to have loads of fun on a rigid 26" Inbred. It was horrible, 2" too big, had awful unbranded cable discs I found and a pick and mix selection of gears but it was great. I did N-S Wales on it and once rode it to Brecon with a bivvy along the way, took part in the Brecon Beast then rode home again. Adventure is most certainly attitude and spirit and certainly doesn't stem from tyre / wheel size or handlebar type.
I still (occaisionally) use a 1996 Univega Alpina 504 for the type of trip you mention. Couple of years back did (amongst other trips) the Cairngorms Outer Loop. Back in the day used it for lots of similar style trips.
Not sure what your tyres are like but maybe consider less nobbly if more gravel/tarmac invoved. Currently running 2" Land Cruisers at the moment, cheap and cheerful but fine for what I'm doing on it. I would also recommend bar ends for the usual reasons, mine are the L shaped (on 66cm wide bars) which look a bit strange but allow me to get a bit more stretched out when needed.
Interesting how bikes of that era make (made?) excellent "gradventouring" bikes long before cycling erupted into all those niches.
Can't help thinking that you'll have a far better time riding this.
*insert adventure in place of gravel if you like.
on thisTerrain will be Single trak, natural trails, forestry gravel roads, tarmac that resembles forestry roads and tarmac
than you will on a gravel* bike.GT Aggressor XC2, Rockshox Recon forks lockout, Shimano Deore group 44/32/22 & 10/32 cassette, hydro Discs, Alex DP17 rims (26"), Panracer fire xc pro 2.1" rubber.
That's the sort of thing my son and I use. Hard tail MTB with 26" wheel. We tend to use semi slick tyres ie low tread in the centre and knobbly bits on the outside. They work pretty well for all but the wettest conditions. We have many adventures and travel many miles on such setups.
I am trying to recover from a rib injury just now and so I recently rode with my road club on my hard tail mtb for the comfort the front sus would offer. I was quite surprised at how much slower I was than the rest, even on the semi-slicks. I knew it would make a difference, but I hadn't realised quite how much.
So I guess a gravel bike or similar would help with covering more miles faster, but don't let the lack of one put you off getting out there. On a rocky descent you will be very glad of the front sus.
- Single Speed George
mountain bikes are fine for bike packing. adventure bikes are for the gullible with money to spend being told they must have a "bike packing bike" whilst brousing an alpkit store to find a mug to dangle or people doing lots of gravel miles if you want to do many nice bike packs in the uk a mountain bike is far superior
- In Reverse
Oh absolutely. That's not to say that tinkering isn't an option though.Bearbonesnorm wrote: ↑Fri Sep 06, 2019 9:22 am Adventure is most certainly attitude and spirit and certainly doesn't stem from tyre / wheel size or handlebar type.
Faster rolling tyres and more comfortable bars exist for a reason after all.
