A while coming but Acepac luggage is now available int' shop. It's all made from Cordura Ecomade, a material produced from recycled plastic bottles but please don't let that put you off, it's waterproof and very tough.
Anyway, if you want a look ...
https://bearbonesbikepacking.co.uk/shop ... at=luggage
Acepac - for them that were asking.
Re: Acepac - for them that were asking.
Just dropped you a mail due to not reading your last email to me properly!
Apologies in advance as I'm sure this is going to be annoying!
Are you going to do the small under saddle top tube pack you can see in the saddle bag pic too? Been thinking about one of them for a while.
Also, what's the width and length of the top tube back (1.2 litre).
Thanks Stu, they all look good.
No plans to. I have one here but they just seem too small to be of much real use - however, that's just my opinion and I'm often outnumbered when it comes to things like that.Are you going to do the small under saddle top tube pack you can see in the saddle bag pic too? Been thinking about one of them for a while.
Width is 50mm but more like 60mm with things in it. Length 260mm. Height at the front is 120mm tapering to 65mm at the rear.Also, what's the width and length of the top tube back (1.2 litre).
Thanks, might do some measuring tomorrow. The top tube bag I've got is a bit long in the tooth and had been repaired a few times.
Nice. Any chance showing weights in the descriptions pls?
Good call Reg, I'll get the scales out over the weekend.Any chance showing weights in the descriptions pls?
