Son28 hub spoke issues
So iv been reading on net about there being a few issues with these closing the gap between spokes and brake caliper on 160mm rotors? Anyone experience this ta
Re: Son28 hub spoke issues
Have a word with Shona Mike, they've lots of experience with SON so should know about any issues.
Cheers stu
Yes they do.
No problems on my road bike. BB5 and Spyre caliper worked on a Kinesis carbon fork with 160mm rotor.
On my Krampus the angle is tight but a BB7 fits - just with either 180 or 203mm rotor. Problem is compounded by very off centre spoke holes on a Fatlab 55 rim.
With a Love Mud Juice on the same bike and rim a Spyke caliper would not fit at all and a BB7 required a little love from a Dremel to get clearance.
On a 26er Thorn with Magura Odur fork there was bags of clearance.
I had it with an SP hub. Solution is to space the disc away from the hub.
e.g. Hope 6 Bolt Hub Disc Spacer https://g.co/kgs/iuZJyZ
Plus one for the above solution, again with an sp hub, but I used m5 stainless washers to shim it.
