1m long carbon pole - 11g
Re: 1m long carbon pole - 11g
Have they arrived?
Yes. Now sat in a box under my bench ... I'm up above my ears in stuff to to do and it's not at the top of the listHave they arrived?
Happy New Year, any progress on the spreader poles?
Not yet convinced it's going to work without some mechanical means of holding the sections together. I had hoped the tension of the tarp would do the trick but in a wind the tarp moves and obviously both sides don't move in unison, meaning the tension holding the sections together comes and goes, blah, blah.
I'll keep at it.
I'll keep at it.
Waves
I assume you’re using shock cord like Warbonnet?
The downward pull of the tarp I would think also holds the joints together?
Are you not listening?
Not yet convinced it's going to work without some mechanical means of holding the sections together. (WB are using hollow DAC sections, I'm using solid carbon rod)I assume you’re using shock cord like Warbonnet?
I had hoped the tension of the tarp would do the trick but in a wind the tarp moves and obviously both sides don't move in unison, meaning the tension holding the sections together comes and goes.The downward pull of the tarp I would think also holds the joints together?
More reading while on conference calls.
The joy of protyping in engineering
Does this flex enough to make a half moon in a Bivi entry?
It would but it would all depend on the length of the pole, obviously the longer it is, the more flex available and the less stress involved.Does this flex enough to make a half moon in a Bivi entry?
Thinking like a D - flat section 100cm and curved pole 130/140cm, pole in sections, 3 or 4 pieces
Possible Stuart?
Possible Stuart?
Should be. I'll go and see what I've got.Thinking like a D - flat section 100cm and curved pole 130/140cm, pole in sections, 3 or 4 pieces
Possible Stuart?
