long grips
Mariner
long grips
Post by Mariner »
I am looking for some long say 150ish mm lock on or double lock on grips.
Preferably in something soft and grippy.
The only ones I have found (Superstar) are currently sold out.
Any suggestions for other makers?
Also anyone using Jones Kraton grips and would care to offer an opinion?
I know they are not lock on but are close to what I am looking for.
windjammer
Re: long grips
Post by windjammer »
jones grips from keeppeddaling in manchester
Re: long grips
I have these on my Loops
https://www.sjscycles.co.uk/handlebar-t ... ars-black/
SJS have various other types of foam grips too. None of them are lock-on but I've had no issues with mine.
Mariner
Re: long grips
Post by Mariner »
ScotRoutes wrote:I have these on my Loops
How are you attaching them to the bars?
Given that they are specified for drop bars how does the difference in diameter effect fitting and removal.
My levers and shifters are not hinged clamp so if I need to remove them - if ever - the grips need to come off first.
Gummikuh
Re: long grips
Post by Gummikuh »
I have the ESI xtra chunky XL grips on my Jones, however I have wrapped the inner loop part with Cinelli chunky or something. The ESI grips are rubbish against brambles and are ripped to shreds.
I have those foam grips on another bike and stick them on with hairspray they are much better and half the price of the ESI's plus you get an extra pair.
I can't see any grip working around the loop part, apart from a wrap.
Re: long grips
3M Photo mount works well, sticks foam grips solidly even to Ti bars (ooh get me...). More reliable than hair spray ime. A can lasts ages. A bit of meths gets them off.
Re: long grips
Mine are currently held on by friction alone. This has worked for me since my first set of Jones Bars, so around 7 years. I imagine they might go a bit loose if you were constantly removing and refitting them. It's a relatively cheap option to try.
Mariner
Re: long grips
Post by Mariner »
Sounds like a lot of faff compared with a couple of grub screws.
Are the Suprestar build it yourself lock on foams any good?
Chew
Re: long grips
Post by Chew »
I have some Hope Lock on grips on my Jones Bars
Think they are ~130mm
They are slightly tacky, so no issues with grip
Re: long grips
I'm not really understang the long grip thing ... buy wide bars to give more 'control'. Fit long grips meaning that your controls are now inboard as they would be if you had narrower bars, braking now needs to be carried out from the 'narrow' hand position ... resulting in potentially less 'control' :???:
NewRetroTom
Re: long grips
Post by NewRetroTom »
As above I feel that with my hands at the end of the bars I need to be able to have a finger on the brake lever. For my Tour Divide setup I used the 210mm ESI grips, but cut them so that about 50mm was inboard of my brake levers. This meant I had another option of where to put my hands when in cruising mode.
Mariner
Re: long grips
Post by Mariner »
Bearbonesnorm wrote:I'm not really understang the long grip thing ... buy wide bars to give more 'control'. Fit long grips meaning that your controls are now inboard as they would be if you had narrower bars, braking now needs to be carried out from the 'narrow' hand position ... resulting in potentially less 'control' :???:
Agree - partly.
The Jones recommendation is the controls set inboard but not quite at the bar junction. If you are taping the inner and outer in one you have room for a turn on the outer side of the junction. I have also seen ESI grips cut with a short section inboard of the levers - someone will be along with a photo soon. :wink:
Not using I-Spec levers and shifters takes up an inch or so plus I position the lever for one or two finger use. Its not really a stretch from the outer hand position to the brakes but it does require moving hands inboard for brake and shifter.
Works for me and I have been using a 120mm lock on as a temporary grip for the past three years on a 710mm Loop.
On a long trail ride use of the brakes and shifters is minimal anyway plus I am using front loop hand position and occasionally forearms across the loop.
I need to replace the temp foam ones so its just the gap between 'standard' grips and my levers I am looking to fill without using ESI type push ons.
(I suspect I may be going to use Jones Kraton grips but hanging out for lock ons.)
Chew
Re: long grips
Post by Chew »
These are set up so I can have my palm on the edge of the bar and still one finger brake.
If you're going downhill on technical terrain you'll need to use the advantages of both at the same time.
Theres then the secondary position where you can place your thumbs inside the loop and rest your palms on the taped bar.
Moving the controls in further means you way not be able to get your hands in that position, as theres stuff in the way.
Before you buy anything i'd have a play around putting the controls in different places to see what works.
Even if that means an afternoon of riding up and down the street with an allen key in your pocket.
Re: long grips
My controls are mounted a bit outboard of the bar junction
These are the wider loop bars.
I like the choice if hand positions and I'm not a big guy so having the controls at the position a normal length grip would dictate feels a but wide for me.
+1
Mariner
Re: long grips
Post by Mariner »
Er couple of years too late for that. Been there done that still got the allen key.
ImageP1150533 by michaelandamanda, on Flickr
The OP was to try and fill in the gap using a lock on not a push on. :-bd
Tango
Re: long grips
Post by Tango »
I’m looking a Jones H bar for my build, interesting to hear the thoughts on hand and equipment position
Hamish
Re: long grips
Post by Hamish »
I bought two pairs of rubber coated lock on grips, cut a length off each grip so that two grips are the right length and placed them back to back so there is a lock on at either end and the cuts butt together. Works fine. I used a fork steerer cutting guide to cut the grips square.
Mariner
Re: long grips
Post by Mariner »
Hamish wrote:I bought two pairs of rubber coated lock on grips, cut a length off each grip so that two grips are the right length and placed them back to back so there is a lock on at either end and the cuts butt together. Works fine. I used a fork steerer cutting guide to cut the grips square.
I like that idea how did you anchor them to stop them moving independently at the join?
Hamish
Re: long grips
Post by Hamish »
I didn't anchor them at the join, just butted them together. Because the rubber is carried on a chassis of rigid plastic, the lock on ring at the end of each half keeps them firmly in place.
Imageimage by Hamish Osborn, on Flickr
Mariner
Re: long grips
Post by Mariner »
Hamish wrote:I didn't anchor them at the join, just butted them together. Because the rubber is carried on a chassis of rigid plastic, the lock on ring at the end of each half keeps them firmly in place.
Like that even more thanks.
