looking for a shimano rear hub or W.H.Y?
135mm OLD
10 speed compatible.
C.Lock or 6 bolt don't mind which.
Ta.
WTD. rear hub.
Re: WTD. rear hub.
Wiggle have got deore m6000 10 speed hubs for £21.99 mate
Re: WTD. rear hub.
I've got a 6 bolt deore one you can have for a tenner. Currently laced to a bent rim, so you could have spokes too if they're any use?
Re: WTD. rear hub.
Good tip, thanks!middleagedmadness wrote:Wiggle have got deore m6000 10 speed hubs for £21.99 mate
My brother is looking through his spares for me. If he doesn't come up with the goods, that'll do perfectly.
Re: WTD. rear hub.
Thanks PaulE, but looks like I might be sorted (come on bro!).PaulE wrote:I've got a 6 bolt deore one you can have for a tenner. Currently laced to a bent rim, so you could have spokes too if they're any use?
Might be in touch if it falls through.
Re: WTD. rear hub.
No problem, I found the wheel in the corner of the garage when looking for something else so it's not going anywhere!
Re: WTD. rear hub.
Cheers buddy, but my bro has come through with a beautyPaulE wrote:No problem, I found the wheel in the corner of the garage when looking for something else so it's not going anywhere!
Re: WTD. rear hub.
Sounds exciting. What did he find in spare parts bin... a Chris King??techno mail wrote:Cheers buddy, but my bro has come through with a beautyPaulE wrote:No problem, I found the wheel in the corner of the garage when looking for something else so it's not going anywhere!
Re: WTD. rear hub.
Not quite, still a quality item though, a Hope pro2redefined_cycles wrote:Sounds exciting. What did he find in spare parts bin... a Chris King??techno mail wrote:Cheers buddy, but my bro has come through with a beautyPaulE wrote:No problem, I found the wheel in the corner of the garage when looking for something else so it's not going anywhere!
