FS: Wildcat Frame bag
Farawayvisions
Post by Farawayvisions »
£35
Wildcat Leopard - dual compartment, map pocket, wrap straps, and hose port.
55cm - top tube
32cm - seat tube
62cm - down tube
Why is this such a bargain?
Well there a couple of issues that you need to know about.
I'm pointing to the zip that is not working as well as it should. It doesn't always close perfectly but does eventually close after a few goes. This happened because too much stuff was crammed in. We did not heed the TLS warning!
I can only include 1 photo here, but can send you more if needed. The velcro along the top tube has come away from the bag about 14cm of it. It is tacked on at the end and works well enough. Again, this was probably because we didn't adhere to TLS rules of engagement.
The actual bag is in really good condition - no rips, holes or tears.
Last edited by Farawayvisions on Sat Apr 28, 2018 9:10 am, edited 1 time in total.
jBay
Re: FS: Wildcat Frame bag
Post by jBay »
Used on a Genesis Longitude?
Farawayvisions
Yes.
Beth would probably fix it up for the new owner - or old owner - for a small charge.
