FS: 8 Speed and 11speed Alfine Wheels
I have an 8 Speed Alfine wheel and shifter. Wheel is built on a stans flow 29er
Also, an 11 Speed Alfine wheel and shifter, Wheel also built on a stans flow 29er
Bought off here, never used, now getting in my way.
£75 for both of them, but they need collecting from Glossop (Or Ansty, Coventry at work) as I am far too idle to sort a proper box out and post them.
Ta.
PaulE
Re: FS: 8 Speed and 11speed Alfine Wheels
Post by PaulE »
Are they the disk version, and have they got the anti-turn washers included? I'm only really after 1 wheel but would take both!
Brothersmith
Post by Brothersmith »
I would take the 11spd if disk and Paul wants the 8spd
PaulE
Post by PaulE »
Works for me...
Deffinately anti turn included for 1 hub, I'm pretty sure for both though.
Yes both disc.
Fine to split for me. You can half the £75 each or argue about it amongst yourselves :grin:
Brothersmith
Paul, happy with £32.50? I already have a set of nuts So there yours if only one going.
Malc
PaulE
Post by PaulE »
Sounds good. I'll hunt out a shifter once the kids are in bed and then send you a pm
Paul E. The 8 speed has no axle nuts and no disc disc lock nut.
The only anti turns I have are 1 specific set that worked with a salsa el mar frame on the 11 speed. But malc seems to think he doesn't need them.
I posted a minute ago that it wasn't disc but I was being an idiot. It's centre lock and there's a rubber cover over it.
Brothersmith
Think I have a set, will have a hunt in the garage tomorrow. If not I have an 8 spd Alfine and if you can swap the lock nuts between them I am happy for Paul to take em
