Brake adaptor
rufus748
Brake adaptor
Post by rufus748 »
Recently bought a set of second hand road hydro shifters with flat mount calipers.
My frame isn't a flat mount nor is the fork :roll:
I'm struggling to find an adaptor, is there such a thing or do I need to replace the calipers?
Re: Brake adaptor
Hmmm, I don't think you can go flat mount to IS or Post mount.
Re: Brake adaptor
I've got flat mount road calipers on my road bike, and my kinesis cross bike has flat mount on the rear with flat to post adaptor.
Looking at these, I'd get a new caliper tbh, as I can't really see how you'd do it the other way round easily, and no-one seems to sell them (at a quick search).
Al
Re: Brake adaptor
Post by Al »
I’ve done the same thing - pair of SRAM force hydros of the classifieds.
My googling led me to this:
https://www.bike-discount.de/en/buy/sra ... gL0j_D_BwE
rufus748
Re: Brake adaptor
Post by rufus748 »
FlatlandAl wrote:I’ve done the same thing - pair of SRAM force hydros of the classifieds.
I've got one of those on one of the calipers and the distance between the outside holes is too short for the frame/fork mounts.
New calipers required.
Potentially (another) stupid question but I assume any make caliper is compatible with Sram levers?
Re: Brake adaptor
Nay, the rate at which the master drives fluid is different SRAM to Shimano - think cable pull rates.
pistonbroke
Re: Brake adaptor
Post by pistonbroke »
I'd be very surprised if you could mix say Shimano and SRAM, the barb and olives are different for a start, given the petite size of SRAM road calipers, you may also struggle with swapping to mountain ones as the bigger pistons may need more fluid to push them causing the levers to have too much travel. Sorry to be negative but a) it's brakes and b) cycle components tend to be non interchangable these days.
rufus748
Re: Brake adaptor
Post by rufus748 »
I was looking at the shimano road calipers BRR785MPRF to work with Sram rival 1 road shifters.
No?
Re: Brake adaptor
SRAM use DOT 5.1 in their brakes, Shimano use mineral oil. You can't mix without destroying seals.
rufus748
Re: Brake adaptor
Post by rufus748 »
Sram it is then.
Shame as shimano calipers are half the price :roll:
Al
Re: Brake adaptor
Post by Al »
Bugger.
Is it possible to buy a post mount SRAM calliper without a brake/shifter attached to it?
rufus748
Re: Brake adaptor
Post by rufus748 »
FlatlandAl wrote:Bugger.
Only place I've found so far is bikeinn.
Al
Re: Brake adaptor
Post by Al »
rufus748
Re: Brake adaptor
Post by rufus748 »
I was thinking more this:
https://www.bikeinn.com/bike/sram-spare ... 36336088/p
Hope do the rx4 but the cheapest I can find is £63 an end.
Al
Re: Brake adaptor
Post by Al »
Wow, not cheap. Makes a bit of a joke of my ‘bargain’ purchase getting the levers!
Only another tenner for the hope ones.
We need like a a sram Caliper dating site where we can swap with someone who has just bought a new flat mount frame...,
In Reverse
Re: Brake adaptor
Post by In Reverse »
rufus748 wrote:Recently bought a set of second hand road hydro shifters with flat mount calipers.
That's just given me a right laugh. :lol: :lol: :lol:
rufus748
Re: Brake adaptor
Post by rufus748 »
You should be booking flights not trawling forums :wink:
In Reverse
Re: Brake adaptor
Too busy riding bikes m8 :grin:
tbf I've done the same thing when buying second hand stuff. Bought some forks that had a 1 1/4" steerer tube (Giant Overdrive) without realising. Turned out that NO bearing manufacturers made headset bearings in that size to fit my frame. :roll:
