New Salsa carbon bars .....thoughts
Been looking at getting some cowbell bars for the gravel bike.
Not so sure about carbon bars on a gravel
Thoughts?
https://salsacycles.com/culture/new_coc ... s_and_more
Thoughts?
Re: New Salsa carbon bars .....thoughts
Looks a nice range
Can’t see a problem with carbon bars on a gravel bike, used carbon rigid bars on my mountain bike for years without problems
$215 for bars..... have some Kool Aid.
On another note, carbon for bars is fine, until you crash hard.
Tempted, but..... $215
No problems with carbon bars.
Someone has been looking at what Enve are charging.....
On the other hand boggo cowchippers are $50. Not once they've crossed the Atlantic though.
I'd have a pair of Carbon Cowchippers. Pretty much perfect for my need/wants. Bit more flare (not flair, but that as well) than my ally cowbells, - woodchippers not for me.
But the ally cowchippers are already way pricey. I'm not going to spend more than double that for a bar that's 75g lighter, when I'd be sticking it on a Singular Peregrine. If I had an Open UP, maybe, but then if I had the money for an Open UP, $215 on bars wouldn't be a problem either.
My wife has been crashing carbon bars for years and there has never been a problem. One bike in particular, which she sold to a friend, must have hundreds of falls on the same bars, they're still going strong.GregMay wrote:$215 for bars..... have some Kool Aid.
It's not about the 75g, it's that they are both stiffer AND more absorbent!nedrapier wrote:I'd have a pair of Carbon Cowchippers. Pretty much perfect for my need/wants. Bit more flare (not flair, but that as well) than my ally cowbells, - woodchippers not for me.
- ZeroDarkBivi
I am building an Open UP, and going for Easton EC70 AX bars - a bit like Cowbells, similar weight, but a bit cheaper (once you add all the tax & duties from importing). They are more than double the price of the Alu version, and only 70g lighter, but I am hoping it will be much more pleasant for long days on bumpy surfaces, although I expect the truth is the right bar tape will be much more important.johnnystorm wrote:It's not about the 75g, it's that they are both stiffer AND more absorbent!nedrapier wrote:I'd have a pair of Carbon Cowchippers. Pretty much perfect for my need/wants. Bit more flare (not flair, but that as well) than my ally cowbells, - woodchippers not for me.
http://www.chainreactioncycles.com/east ... 7C582811UK
Was looking at those the other day, quite temptedZeroDarkBivi wrote: I am building an Open UP, and going for Easton EC70 AX bars - a bit like Cowbells, similar weight, but a bit cheaper (once you add all the tax & duties from importing). They are more than double the price of the Alu version, and only 70g lighter, but I am hoping it will be much more pleasant for long days on bumpy surfaces, although I expect the truth is the right bar tape will be much more important.
My mate has fitted a set and is happy with them:Lump wrote:Was looking at those the other day, quite temptedZeroDarkBivi wrote: I am building an Open UP, and going for Easton EC70 AX bars - a bit like Cowbells, similar weight, but a bit cheaper (once you add all the tax & duties from importing). They are more than double the price of the Alu version, and only 70g lighter, but I am hoping it will be much more pleasant for long days on bumpy surfaces, although I expect the truth is the right bar tape will be much more important.
https://advntr.cc/easton-ec70-ax-carbon-handlebar/
