Something to cheer you up.
https://www.theguardian.com/artanddesig ... n-pictures
Warning contains explicit scenes of bike frames, tubes, fittings, machine tools and oily hands.
Do they really solder the steerer to the fork crown?
Never knew that about changing the thickness of the tubes.
Blue Monday?
Blue Monday?
Re: Blue Monday?
Blue Monday is bobbins.
But Dolores O'Riordan has died.
Re: Blue Monday?
'Soldering' isn't technically correct - it will be brazing or silver soldering, both of which use more heat (oxy acetalene) than what a plumber may do and either brass or silver filler. Its nearly as strong as a weld but involves less heat and distortion.Mariner wrote:Something to cheer you up.
Re the wall thicknesses - find a good steel frame and ting the tubes with your nail, they will be higher pitched tings in the centre of the tube due to the reduced wall thickness - all part of the magic of steel frames
Re: Blue Monday?
Nice little animation here showing how butted tubes are made.
https://www.youtube.com/watch?v=QKAg1yMZIpY
- thenorthwind
Re: Blue Monday?
Thanks for the link, very interesting.
Proper workshop envy
What a shame that his subtle choice of the Greek messenger of the gods Hermes for his signature lug shape is somewhat tarnished by most people's (I assume) first thought when they hear the word Hermes these days
- In Reverse
Re: Blue Monday?
People get a bit carried away imho - you can clear it up with some over-the-counter cream.thenorthwind wrote:y most people's (I assume) first thought when they hear the word Hermes these days
