The one bike conundrum
- Laurensdad
A recent change in work arrangements has upped the bike commute distance and frequency. I'm moments from clicking go on a bike that will do the 18mile each way commute on 700 x32's and then accommodate 27.5 x 1.9/2 ish tyres for more offroad trail stuff. Anyone got any experiences of a similar setup? Cheers Phil
@philg1971 Instagram
- ZeroDarkBivi
Re: The one bike conundrum
Sounds like a sensible choice; WTB 650b Byeway tyres (47mm) should see you good on road and non-technical, dry off-road.
- BigdummySteve
Salsa Fargo would be my choice, mainly because I have one. It’s a lovely thing. A couple of wheel sets and your good. If you’re near Oxfordshire or at the winter event you’re welcome to have a spin.
I commute on my Fargo and it's a right leaden lump compared to my Arkose. A fraction of the cost too now that Salsa prices have got silly.BigdummySteve wrote:Salsa Fargo would be my choice, mainly because I have one. It’s a lovely thing. A couple of wheel sets and your good. If you’re near Oxfordshire or at the winter event you’re welcome to have a spin.
- BigdummySteve
Yes but it’s a proper mountain bike in disguise.
Salsa Marrakesh. I was looking at these a couple of days ago and found this blog http://bikepacker.com/mission-part-2/ The bloke is running 2.1 tyres on it.
Do a 7 mike commute each way on my Salsa El Mariachi and then ride it on the ‘weekends’ too, cracking bike. Shame they don’t make it anymore (so not a helpful comment)BigdummySteve wrote:Salsa Fargo would be my choice, mainly because I have one. It’s a lovely thing. A couple of wheel sets and your good. If you’re near Oxfordshire or at the winter event you’re welcome to have a spin.
Specialized Diverge? Friend has one with 24mm tyres, pretty rapid to be fair and it can take up to 40mm tyres too (in the 700 flavour).
Any pictures of it built up?voodoo_simon wrote:Do a 7 mike commute each way on my Salsa El Mariachi and then ride it on the ‘weekends’ too, cracking bike. Shame they don’t make it anymore (so not a helpful comment)BigdummySteve wrote:Salsa Fargo would be my choice, mainly because I have one. It’s a lovely thing. A couple of wheel sets and your good. If you’re near Oxfordshire or at the winter event you’re welcome to have a spin.
How about a Specialized sequoia?
Very true, but my 38-40c tyres look lost in it. 32c road tyres will have the pedals dragging on the corners!BigdummySteve wrote:Yes but it’s a proper mountain bike in disguise.
Kind of. I had the same idea and wanted to achieve the same thing. It seemed obvious that you can put skinny tyres on a big frame, but not big tyres on a skinny frame. Plus, I was on a budget. So, I took my 27.5 hardtail, made it rigid, then grabbed a second set of wheels for my commuter tyres. I could go and push very skinny 700c wheels in to the frame, but stuck with 27.5 2" commuter style tyres (Schwalbe hurricanes).Laurensdad wrote:A recent change in work arrangements has upped the bike commute distance and frequency. I'm moments from clicking go on a bike that will do the 18mile each way commute on 700 x32's and then accommodate 27.5 x 1.9/2 ish tyres for more offroad trail stuff. Anyone got any experiences of a similar setup? Cheers Phil
I could also spend some money and do a drop bar conversion, but right now, I'm happy with my Og bars.
Compromises are always compromises. Whilst I get the one bike / multi wheels idea the reality never really works, especially if you are a regular commuter and your commute is on road.
I can't be doing with swapping wheels, adjusting brakes, compromising on ride position between road commute and off-road trekking, faffing with saddle bags, lights, etc.
My commute bike is a road bike, it has road tyres (max 28mm), mud guards, rim brakes, decent but not top-end gearing, saddle bag with repair kit always fitted, lights attached and ready to go; it goes for miles and miles with the occasional wipe down and lube and is always ready to just grab and go. I don't have to spend time swapping parts out between rides.
Makes life a lot easier and that bike probably cost less than a decent set of wheels and tyres...
(Mind you, I do sometimes grab a hardtail for the commute and take the scenic route home )
