Following on from the Bridget's 'can I paint my bike' thread, I thought I'd conduct a diy hydro dipping experiment ... pair of forks next I think
DIY 'Hydro-dipping'.
Re: DIY 'Hydro-dipping'.
I had a friend who was convinced this was the next "thing" in car and bike part modding and invested into it heavily.
He now has a lot of stuff and few clients. It is quite cool though.
Luckily my monetary investment is zero and will hopefully remain thusI had a friend who was convinced this was the next "thing" in car and bike part modding and invested into it heavily.
Camo/Realtree patterns on Air rifle stocks used to be big business.GregMay wrote::)
Nice. Looks good. Was it fiddly/tricky?
Not really Bridget. I did some reading up, then in my usual style ignored pretty much everything I'd read and just had a go with what I had to hand.Was it fiddly/tricky?
People say:
You need to add Borax to the water - I didn't bother.
You must use enamel paint - this is acrylic.
Water must be around 78 degrees - mine just kind of felt about right.
However, I'm sure following the advised steps properly would result in a finish that requires less work after dipping. Ideally, I'm going to experiment a bit more with paints and find something that won't 'skin' as that tends to produce a rougher surface when you lift the parts from the tank (bucket). I'm wondering whether ink might produce decent results rather than paint ... we'll see.
