Someone linked to these on STW, just wondered if anyone had used the stoves or pot stands, all looks very light and also cheap!
https://speedsterstoves.co.uk/index.php
Joe
Speedster Stoves - Anyone used them?
Re: Speedster Stoves - Anyone used them?
They're open cylinder stoves, so don't produce the same output as a pressurised stove will. They're cheap because they're a screw top tin you put meths in and light ... yes, they have a wick but it's not required and doesn't aid performance.
Empty one of these ... pretty much the same thing or promise to put 2 quid in the next Guide dog box you see and I'll send you one.
I have a Vaseline tin stove
Now very efficient but it's simple and works. I put esbit blocks in the lid and meths in the bottom (I used stove insulation as the wadding/wick). Fits nicely in a Pocket stove
