Random question....but
Mike
Post by Mike »
Does anybody have a use for about 8/10m of the blue mains water pipe that they need, I have some here in my shed that has been waiting for a home since I put a new water main to my house ;) let me know if anyone can use it
Re: Random question....but
Cut a 2' length off and carry it with you ... cows are scared of it*
*true fact.
Mike
Post by Mike »
haha where did that fact come from stu? There arnt many cows in wales and as most of my riding is there normally so not an issue for me. What about the sheep though. I hear wellies and velcro on the gloves are worth carrying........Baaaaaaa :lol:
And having seen you mount a lass from behind whilst her head was stuck in a fence.....great technique btw ( ill try and find the evidence ) A master at work
Scattamah
Post by Scattamah »
Mike wrote:...I hear wellies and velcro on the gloves are worth carrying...
I have it on good authority that all you really need is teeth and the urge.*
*True fact - he was a filthy rotter
ctznsmith
Post by ctznsmith »
What diameter is it? I may have a use.
Another fact, the Morrocan police in Tangiers use two metre lengths of it to beat beggars off the beach. I've seen it with my own eyes.
Dave Barter wrote:Another fact, the Morrocan police in Tangiers use two metre lengths of it to beat beggars off the beach. I've seen it with my own eyes.
Random fact, blue poly pipe should onlt be used for the below ground conveyance of potable watet (water bylaws) so for beating beggars (or scaring cows) one should use black poly pipe which is uv resistant :lol:
If ctznsmith doesn't want it I'll have it please.
I need to make some new cloches for my garden veg plot over this winter and I can use this poly pipe to make the arches.
BB200 pick up?
Mike
Post by Mike »
Will measure tomorrow... And yes John if it doesn't go ill bring it to bb
If I had a mate who wanted to understand the spirit of bikepacking in a nutshell I'd point them in the direction of this suitably surreal thread :-bd
ctznsmith
Post by ctznsmith »
Thinking about it the maximum likely diameter is going to be ~ 60mm which is too small* for my use. John it's all yours.
*Anybody got any spare drain pipe? :-bd
ctznsmith wrote:Thinking about it the maximum likely diameter is going to be ~ 60mm which is too small* for my use. John it's all yours.
PE80 (poly water pipe) is listed in my brochure from 20mm to 1000mm. These are external diameters as that's how plastic pipe is measured. Depending upon the pressure rating the wall thickness does vary but for a 20mm pipe it's about 2.5mm and at 1000mm dia it's about 63mm. If you want a piece of drain pipe then I'm guessing that you're after about 110mm dia? The wall thickness is 10mm for this size. If you know someone who works for a civil engineering or utilities contractor they may be able to get you an off cut provided it's not too long. One of the benefits of PE pipe is that it can be joined by butt-fusion where the ends are heated by metal plates and then the two bits are forced together and they fuse together, so no fittings are required at a join. The downside of this is that any off-cuts on sites tend to get joined up and used rather than just slung out for us to re-purpose.
ianfitz
Post by ianfitz »
There's no way I could work in an industry that has an actual process called ...
sean_iow wrote:
butt-fusion
I'm way too childish to be able to say that without laughing. A lot.
TheBrownDog
Post by TheBrownDog »
True. I worked on a cattle station in central Queensland for a few months and on musters we were all armed with four foot lengths of black poly piping to batter the cattle into the different pens as they came through the runs. Worst. Job. Ever.
In Reverse
Post by In Reverse »
ianfitz wrote:There's no way I could work in an industry that has an actual process called ...
sean_iow wrote:
butt-fusion
Ask Stu about fully-penetrative butt welds. :o
Or don't. :-bd
