Any shimano 105 or better levers for my arkose available out there? 9 spd would be good or 10 spd double if not. Will consider sram also. As long as they work with shim mechs and they need to work with trp spyres :)
Ta
Wanted road levers
- pushbikemike
Re: Wanted road levers
Hello Mike, if you are still looking for levers I'm pretty sure I have a set of 105's 10 Speed doubles in the shed.
Mike
Mike
Hi mike thanks can u send me some pics please to mikeclarke87@gmail.com when you get five cheers
Mike
Mike
I've a set of 10 speed campag centaur, which apparently work with 9 speed Shimano if you clamp the cable differently (hubjub mod, I believe it's called). They worked nicely for me with avid BB5 brakes so the cable pull should be fine with trp.
Mike - the whole SRAM / Shimano thing - not compatible, using widgets to make them compatible is a faff.
One of the other, so probably Shimano if you've got the mechs already.
yes Greg iv got the mechs and would stick with shimano anyhow. Cheers for the advice! Not keen on sram ( never used though )
I'm after the newer style levers where without the cables poking out the sides
What's wrong with yer bar end shifters?
Nothing stu just fancied a change and go back to std drops
- pushbikemike
Photos sent Mike.
I got them off here a few months ago from Gairy. My little hands and flared drops didn't go well together.
