Oh... the excess slack in the rear mech didn't seem to affect tuning at all and seems to shift lovely...
Next up, I think I need to find a local grafiti artist to help Sharpie some colour on there with the name...
- ledburner
you sound like the Krays...redefined_cycles wrote: ↑Thu Apr 29, 2021 9:26 pm ... needed finishing off.... So out came the saw and off it came...
4 grams lighter, i'll never keep up..
Now then... Just got back from work. Bought the missus flowers but they only lasted for about 1 hour (actually less) before I'm in the doghouse for not completing the loft already
But before I ended up in that house, I managed to get a few more bits done Alhamdulillah...
Removed the long bolts on top of the stem which held an outfront mount. Now I have 2 ti bolts underneath that might be weak but at least won't look rusty in time. The top ones are steel but time will tell if it's stainless (I suppose I could get out a magnet and not need to wait in suspense).
Then before getting to work on water carrying abilities, I noted this little chain smack/slap groove seems to be a bit deeper than anticipated Oh well, it'll keep me on the edge and also adds character, right!
Then the bolts under downtube came out and a sidelaoding specialized cage went in. Not looking forward to mud splatted on the water bottle spout so might need to put some thought in here...
Kleen Kanteen looks good but you'd still have some splatter arohnd the edges of the cap, right. Other option could be one of them camelbak bottles with the nozzle protector shield (thingy). But expereince of the newer Camelbak bittles has been that they start to stink up too soon even with kust using plain water
Obviously, then I admired it. Butcher (the bike), you little gorgeous little basket you... Hope it rides as well as some of the hype. But... at least the framebag fits snugly!
Stan (the Sonder): RIP
Nice one Shaf.redefined_cycles wrote: ↑Fri Apr 30, 2021 10:29 am Now then... Just got back from work. Bought the missus flowers but they only lasted for about 1 hour (actually less) before I'm in the doghouse for not completing the loft already
Just the ticket for the Dartmoor trip.
I fixed it, but fitting a new inner and outer cable gear cable, rear derailleur, and chain. Although it took so long I didn't get a chance to switch the tyres over.
Thanks to everyone that replied to my utter brain fades today, much appreciated..
Added some Togs thumb grips to the loop of my Jones-a-like bars.
No idea if it will help at all but I find the concept intriguing and I saw a used pair on eBay.
Partly I hope they will stop me obsessing about adding a Gnarwhal extension to the bars.
https://share.icloud.com/photos/02XbCOR ... r_-_Huxham
- ledburner
lune ranger wrote: ↑Sun May 02, 2021 4:05 pm Added some Togs thumb grips to the loop of my Jones-a-like bars.
[/quote]
Ooh, I'd be interested in how you get on.
Took the Terenno Zero's off and put last years Gravel King SK's back on. Sealant pissing everywhere, from both tyres, so took them off again, cleaned them up and put them back on with inners tubes. Then took one back off, patched the hole in the tube, and put it back on.
I have TOGS on a couple of bikes and like them. Never thought of doing that to the Jones bars though. I think that could work well. Very clever.lune ranger wrote: ↑Sun May 02, 2021 4:05 pm Added some Togs thumb grips to the loop of my Jones-a-like bars.
May need a little playing with to find the best position but they feel pretty good on a trip around the block.ScotRoutes wrote: ↑Sun May 02, 2021 9:14 pmI have TOGS on a couple of bikes and like them. Never thought of doing that to the Jones bars though. I think that could work well. Very clever.lune ranger wrote: ↑Sun May 02, 2021 4:05 pm Added some Togs thumb grips to the loop of my Jones-a-like bars.
Will report back when they’ve had a proper run out.
Lukes/Lune Rangers Togs
- gairym
What have I done to my bike today....?
I sat on it and rode somewhere in the region of 30 metres before putting it away again.
I had a vasectomy last Thursday and now that the swelling is going down, the tenderness is a tad less debilitating and I'm hoping we've passed 'peak purple' my thoughts are turning to when I'll be able to get back in the saddle.
Less than 4 weeks to the Tuscany Trail and I need to get some more long days in asap.....fingers crossed!
- ledburner
Keep wearing your budgie smugglers/those undercrackers that are 3 sizes too small . If you don't squeek they're too big!gairym wrote: ↑Mon May 03, 2021 4:37 pm What have I done to my bike today....?
I've Been there.. 'nuf said..
May be Try riding bow legged & standing up,
Drop your saddle etc. Just walk...
Popped a saddlepack on the dropper (once again). Was hoping it'd be light enough for the air pressure in the dropper to counter the weight. But no, pressing yhe lever with the SP on and it wouldn't come up the full length.
Took off thw saddle to get to the air pressure valve. Got the Rockshox pump on it once again and it's already at 200psi. Pumped it as hard as I could to 250 but as soon as I released the valve the excess just keeps coming out.
Then decide I'd let it run as sag. 1.5cm or thereabouts. So I've raised the saddle height instead. Only problem is that when I take the SP off, I'll then need to drop it again. Surely, can't be too hard...
Well yesterday evening. Pulled the rear Hope hub apart and switched a bearing, cleaned out the freewheel (I think some of the water in it was from the River Tilt) re-greased, re-assembled and realised I'd put the pawls in the wrong way round despite actually spending a minute thinking about which way round they go. Not wishing to ride the bike backwards it then had to come apart again Torqued the sprocket lockring up to 40Nm so no chance of changing the sprocket for a cassette now.
Pulled the EBB, cleaned and re-greased. Faffed with some allen keys to ensure I can rotate it mid ride. Stared at the brake pads for a bit then changed the front pair, put a spanner / allen key on every bolt I could find to see if they were tight, put the 'touring' stem on, fiddled with the bar position and put on ergo grips.
Swapped both tyres as the rear was done and the front a bit worn.
All ready for the 22nd!
- TheBrownDog
I installed my birthday present from the kids. After one or two subtle hints, delivered unto me were a set of Surly Sunrise bars and some of those crazy thick Supergripz. These are the 45mm ones. I have hands like t-bone steaks and I'm not sure about them at all. The 55mm ones must be like rolling pins.. As for the bars, I've been after a higher riding position for a while and am really happy with the BMX-clunker-shopping bike look. First proper ride on Saturday should be interesting.
- JohnClimber
May 7th
Fitted mud guards ready for tomorrows ride
- BigdummySteve
Well I gave the drivetrain a serious clean yesterday, I’d ran out of smoove lube and resorted to using an old bottle of muc-off wet lube. It’s the work of the devil. A pristine drivetrain is now black again after today’s 40 mile ride Must but some more smoove ASAP.
While cleaning it I found that the BB bearings were shot again, cleaned them out and regreased but they are rough as a badgers arse. Now I’m an advocate of quality bearings but this Covid thing and divorce has left me hugely skint so……
The postie has just delivered a set of these
EsportsMJJ FEVERWORK 2Pcs 6806-2RS Ceramic Bearings for Cannondale Rotor BB30/PF30/BB 386/BB Right Bottom Bracket https://www.amazon.co.uk/dp/B07BQTN512/ ... UTF8&psc=1
Yes £6 a pair and claiming to be ceramic
I’ll Chuck them in tomorrow while it’s raining, if they last half a year I’ll be happy enough, 3 sets a year and I’d still be quids in compared to my normal bearings. Interesting experiment, with expensive bearings you don’t want to change them very often so normally they are well beyond optimal by replacement time at six quid I’d save the degreasing/ regrease hassle and just bang another set in, as I’ve said recently I treat 30mm bearings as a consumable.
- ledburner
TheBrownDog wrote: ↑Thu May 06, 2021 8:02 pm the BMX-clunker-shopping bike look. First proper ride on Saturday should be interesting.
Sunriser s looks like Ragley and Jones bar-stard love child , but who cares ? .Are they comfy. get some happy mile in!
- BigdummySteve
Knocked out the shot BB bearings then during halftime during the Northampton Saints game (don’t ask) poped in my new über cheap ones. They feel lovely, can’t beat that new bearings feeling.
- ledburner
you end up investing in so many it beBigdummySteve :roll: :lol: wrote: ↑Sat May 08, 2021 9:39 pm Knocked out the shot BB bearings then during halftime during the Northampton Saints game (don’t ask) poped in my new über cheap ones. They feel lovely, can’t beat that new bearings feeling.
.... the New Bearing Bank
- BigdummySteve
Well to be fair you might be right, but there’s method in the madness. My usual quality bearings approach kinda works but I still average less than a year even with the best. So going on usual expenditures I can get nearly 4 sets for the price of one. For the one I’d be popping the seals and regreasing fairly often. I reckon I can put a new set in quicker than servicing the old. And I’m skint so obviously I’ve focused more on the pro’sledburner wrote: ↑Sat May 08, 2021 10:57 pmyou end up investing in so many it beBigdummySteve :roll: :lol: wrote: ↑Sat May 08, 2021 9:39 pm Knocked out the shot BB bearings then during halftime during the Northampton Saints game (don’t ask) poped in my new über cheap ones. They feel lovely, can’t beat that new bearings feeling.
TBH I always have gone for cheaper bearing after the life of the good vs the cheap is pretty much the same, normally get hold of packs of 10 off the bay and just change when they need changing, much better than a pair of bearings for 20 squids a time
- BigdummySteve
Fitted a 2.6” Mezcal to the rear, liked the extra everything with front one and managed to find another cheap . I’ve been liking the 2.6 size, they don’t seem much draggier than the 2.3’s and much much better than the 3” chupucabras on my ECR which I came to hate.
Oh don’t make a phone call right after seating tubeless tyres, I think TBD thought it was a dirty phone call at first
Did you let out an "ooh" at every pop?
I replaced my gravel bike's rear tyre which had worn down to slicks, tubeless popped straight on first time with no mess. Now to leave the sealant to soak into the sidewalls overnight for a ride tomorrow.
