Packed bike weighIn Thread
Re: Packed bike weighIn Thread
All weighed up for an MTL attempt.
16.9kg (or 37.25 in old money)...
2.3L water (so that should come down)
Tools
Lots of food
2 bags
Tools
Lots of food
2 bags
Hey, are you bivvying? That's a pretty compact setupredefined_cycles wrote:All weighed up for an MTL attempt.
Tools
Lots of food
2 bags
Your front mudguard looks back to front...
- TheBrownDog
That'a how I fit mine when I use it too. It stops loads more crap being flung up in to my face.benp1 wrote:Your front mudguard looks back to front...
Nope... not a front mud guard so not back to front... it's Stan (the Sonders) hat...benp1 wrote:Your front mudguard looks back to front...
Nope. I was MTLing...techno mail wrote:Hey, are you bivvying? That's a pretty compact setupredefined_cycles wrote:All weighed up for an MTL attempt.
Tools
Lots of food
2 bags
Not bivvying but have given myself a target limit of 42lb fully packed whoch would include the shelter and sleeping bag on the forks in the 160ish grams Gorilla Cages.
Also water wouldn't be as much and hopefully look at filling up at running water spots.
Excuse my ignorance but, what is MTLing?!
Mary Townley Loop ING
It's a loop on the Pennine bridleway I think.
Hang on.....
https://en.m.wikipedia.org/wiki/Mary_Towneley_Loop
Hang on.....
Yup. Sorry, my bad. Mary Townley Loop which is an additional circular section of the Penning bridleway. Goes around the Lancashire region
Aha, I know it! Thanks guys
How did you find having the bladder in the frame bag?redefined_cycles wrote:Nope. I was MTLing...
I liked it. Have thought a way to make driking from it easier:
Magnet on stem and one of them Osprey magnet attachments that go on bladder tube. That way its easier to drink on the fly and/or the fact it wasn't (yesterday withoit magnet so was mainly drinking when stopped) too easy to drink meant i didnt guzzle it all like I would when sat on back and easy access...
Main thing having its pack aswell was to get the weight up to fully packed targets. So when the shelter/S bag needs to go on bike, water can go on back.
Having nothing on my back felt good for the duration of the ride yesterday though...
Thanks, I've tried it but need a longer hose and find the bladder takes a bit too much space up in my frame bag. Probably gonna go for bottle cages on fork bosses........redefined_cycles wrote:I liked it. Have thought a way to make driking from it easier:
I made a sort of cradle for mine [ resting on bags and between the Gap in some alpkit confusius bars ] using some additional straps for it to rest n and secure it.
Easy to see how much was left but you did have to adjust strapping as it emptied - I did this in the heat wave last summer as i knew drinking enough water was going to be a problem
Water bottles are a lot less faf
I tried a similar tactic with a camelbak unbottle a year or so ago. Discounted it as it Puts a heavy lump in an a less than ideal place which I'm sure affected the handling of the bike and also lurched about when the terrain got lively!Lazarus wrote:I made a sort of cradle for mine [ resting on bags and between the Gap in some alpkit confusius bars ] using some additional straps for it to rest n and secure it.
i did not do anything to technical on it but that is fair point i dont think I would have trusted it [ would certainly have secured it very tightly t the start and probably stopped to check
Its sub optimal solution [ though i have toyed with putting it one of those lightweight runner camelbaks [ which i have as it was cheaper than the bladder alone] as i think you can secure that more easily - but you may as well then just put in on your back anyway - it was so hot i wanted no bag.
Only a heatwave will make me consider this again.
15.6kg
Thibgs I had to leave behind to ensure I only jept with the 3 bags (collapsible osprey bag in back pocket too will go with me):
down rab jacket and merino wapha jacket (which i thought to take instead of the rab)
Coffee making system
Mudguards (or fenders.. whatever they are)
Just done an extreme honesty weigh in and I'm a little shocked.
So this set up is for B150 next month and a test run tomorrow.
This includes absolutely everything I think will start on my bike. IncludesGPS and spare batts, all food I'll start with, water, tools, lights, waterproofs, spare warm gear, emergency bivi.
20.8kg
Salsa Fargo Rohloff - all steel with Nano's.
Guess I could loose a few tools and layers but I wouldn't want to.
Guess I could lighten up the bike but I won't be affording a Ti Fargo anytime soon.
Suppose the stuff you usually avoid counting in an all up weight adds up more than you like to think.
20.8kg
aye the electronics ,water , clothes and food soon add up
i think the bet you can do is get your essential kit that will always go[camping and cooking and tools] with you down to a decent weight
- thenorthwind
Weighed my full-sus (not my usual bikepacking bike) loaded for the Lakeland 200 on Friday - 19.5kg. Rucksack was a further 3kg with no water (a full bladder would bring it up to 5).
Need to weight the bike unloaded to see how much is kit, but the spec weight for a small (mine's XL) is 13.4.kg, though I've changed a few small bits.
I think (I.e. I can't remember) that my bike at last year's WRT was 18kg. That was a Salsa Spearfish which is 12.5kg plus the gear that I intended to use on the HT550 later that month plus whatever food I'd stuffed in the stem cells.
Gear weights were roughly:
Bivy kit: 930g
Bags and harnesses: 930g
Electricals: 750g
Tools and spares: 650g
Spare clothes: 750g
Sundries (FA kit, etc) 350g
The list of actual items is quite long but packed it doesn't look a lot.
Bivy kit: 930g
Electricals: 750g
Spare clothes: 750g
My bike, kit, food and water for the 2017 B150 came to 22.4kg or 49.5lb in old money. That was everything apart from the clothes I was wearing I even took a tarp and poles. This year I'd hope to have a lighter setup.
I'm sure I have a WRT weigh in spreadsheet for multiple years kicking around somewhere...
- In Reverse
21.5kg ready for the Dales Divide. Probably the heaviest I've ever packed - more water and food (a lot more food tbf) then I'd usually take.
It's still not alot of gear though is it?
Most DofE kids carry that on their back and they don't even have a bike!
Being picky but did you weigh in with the bottles full? Because they look empty in your pic Full, they'd be 1.5kg and that's about 8% of your weight right there.
