BB200 2017 - No More Speculation
Re: BB200 2017 - No More Speculation
How close to the 'line' do I need to keep to be riding the route? Until the above talk of accuracy I had planned just to load the gpx into the etrex and ride it on-site. Am I supposed to be adjusting it to exactly match the tracks and roads of my preferred mapping?
Looking at the supplied gpx on basecamp and in google earth the only bit that I'm not sure of (at the moment) is just before the Elan Valley Visitors Centre. Just before that should be drop down the zig zag path just in front of the dam to get to the road that goes past the visitors centre?
With regard to total height, the above quoted 4600m and 220km works out at 110 ft/mile. An average xc ride on the Isle of Wight is 100 to 110 ft/mile and my quick spin around Brighstone Forest yesterday worked out at 148 ft/mile. Unless the route is no steeper than the Isle of Wight (in which case I'll be disappointed after driving all that way ) I'm bracing myself for more climbing than that. I've dropped the gearing on my ss to 32/20 which is what I used on the Braunton 150 but if there is 'only' 4600m of climbing then this might be a little spinny? Any other singlespeeders who've ridden in the area, what ratio do you use?
- ZeroDarkBivi
Thinking about footwear and wondering if there are any river crossings above ankle depth? Would prefer not to have numb feet for 3 months, like after the 2014 event!
My advice is not to get too worried about accuracy. 99% of the time the line on your screen will tally with what you're riding on the ground, any deviation between the 2 won't be noticeable. Anywhere where there is no obvious track or path on the ground, simply use common sense and follow your screen as best you can allowing for the terrain. These sections are generally plotted to follow shown RoW which might bear only a limited likeness to what's on the ground.
Really, it's pretty simple to navigate, it is what it is and doesn't need making more complicated. People will still blindly follow a sheep track and wonder off route, even if the gpx track is accurate to the nearest mm
EDIT: Sorry Craig, missed the ford / feet bit. The only place I can guarantee wet feet is in the last 40km. Although it could happen earlier if you miss the bridge and use the ford but again, that is quite late in the day.
The only bits where gps accuracy might be needed are the road section before Elan village - you should actually be on the path to the right of the road, and then over Carnau where the path is vague at best - my advice would be to follow the line on the gps as whatever path you find is not a path but a sheeptrack or stream.
I was kind of hoping the line showed the cycle trail to the side of the road but regardless, it's pretty obvious when you get to ityou should actually be on the path to the right of the road
If that's the Elan Valley trail (Lake side of the main road), the gpx file shows you as being on that and not the road on the UK Bikepack maps.Bearbonesnorm wrote:I was kind of hoping the line showed the cycle trail to the side of the road but regardless, it's pretty obvious when you get to ityou should actually be on the path to the right of the road
The cycle path is slow and splashy anyway. Take the road.
Also, I assume the plan is for people to use the steps at the side of the dam rather than riding off the top of it? Your gpx routes really are next level awful for accuracy Stu.
Edit - BTW, I get that some need the smaller files for their ancient GPS units. But it would be nice to get half decent ones as an option for those of us living in this century!
Just noticed that you picked the really good rocky descent down to Rhayader (vs the god awful road descent). As long as it's not wet, that bit should be fantastic.
I'm just going through comparing what's on the route to what I've already done. From what I can tell, it's about 10 miles out of the total that's new to me. One bit in particular is quite a large section that's new... Trallwm to Claerwen. Let me guess? That bit's going to be a nightmare?
What concerns me more is that I remember how hard a lot of the other bits were when I did them last time. Going to be one hell of a tough ride.
As I said up-thread, I replotted the whole route in RWGPS and wrote a routesheet. I have checked off with Stuart the bits that were ambiguous from the original GPX and have finalised mine against those notes. He had specific sections that he wanted matched to his version, which I have done. The rest matches the obvious rights-of-way a bit more precisely.Richard G wrote:Edit - BTW, I get that some need the smaller files for their ancient GPS units. But it would be nice to get half decent ones as an option for those of us living in this century!
I have created a one-part medium-resolution course, and a two-part high-resolution course (two parts to avoid a specific Garmin issue). With Stuart's permission you're welcome to a copy — but to maintain the entrants-only status that Stuart requested in his original email, I have to check before I can give you access. Therefore, if anyone would like access to a higher-resolution, plotted-not-recorded GPX, PM me, or email me at nick-at-camaudax.uk and I'll send it over
I have checked the entire RWGPS route over at least three times to make sure there are no idiot mistakes from me (although that's still a possibility). Any of the versions of GPX should get you there, but the higher-resolution GPX files will probably give you least angst at 2am while trudging across Carnau, maybe
For those of an audax background, I've also put my routesheet alongside the GPXes. It can be useful, but it's NOT a replacement for GPS.
I thought this was a bikepacking route not a cruise missile strike?
Judging from some of the traces from previous events people will find their own way across the "interesting" bits. From the sections of the route that I've done it's pretty obvious "on the ground" where you should go, tracks in the countryside rarely follow ruler-straight lines.
If it indicates that you ride off the top of the dam ... then.Also, I assume the plan is for people to use the steps at the side of the dam rather than riding off the top of it?
Have you ever seen one of Mike's?Your gpx routes really are next level awful for accuracy Stu.
Spare a thought for those of us yet to emerge from the 19th century ... and STFU moaningBTW, I get that some need the smaller files for their ancient GPS units. But it would be nice to get half decent ones as an option for those of us living in this century!
- adjustablewench
Ha ha Mike's gpxs may be awful but they aren't a patch on his distance estimations . . .'as the crowd flies it's about...'
One of our rides to get me back out on my bike again was estimated at 'about 30 miles each way' - we did over 100 miles!
Yeah but these days he works in 'Welsh Miles' Wenchie
- adjustablewench
He works in Mike miles - they are far more peculiar
In sure lots of us are the same with time. 'This will just take 20 mins'. 4 hours later....
That's fine, until you're in middle of the night and 10 foot to the right of a semi decent trail (that you didn't see) and desperately hoping that the line actually goes near it at some point.whitestone wrote:Judging from some of the traces from previous events people will find their own way across the "interesting" bits. From the sections of the route that I've done it's pretty obvious "on the ground" where you should go, tracks in the countryside rarely follow ruler-straight lines.
As for stopping moaning. Nope! It's my enshrined right as a bikepacker.
I read this thread. I read Stu's post with that quote in it. I read the rest of the posts. I laughedBearbonesnorm wrote: ... it is what it is and doesn't need making more complicated.
Everyone's in the same boat ... just some people are better at rowingThat's fine, until you're in middle of the night and 10 foot to the right of a semi decent trail (that you didn't see) and desperately hoping that the line actually goes near it at some point.
We all laughed as we were in head height bracken, thrashing through to make a path on the 45° slope, swinging our laden bikes as though they were machetes, BB200'er followed BB200'er each questioning the GPS.I laughed
Then as we emerged from the forest of bracken like lots of General Stilwell's on push bikes, the parade of bracken broken bikepackers saw the path directly below them and chuckled.....
I seem to remember "finding" the start of last year's "interesting" section was made more interesting by the "trail" actually starting from the top of an embankment with you at the bottom!
I've been ten foot to the side of a decent trail in the daylight
Looked like quite a nice path as I recall too.Matt wrote:Then as we emerged from the forest of bracken like lots of General Stilwell's on push bikes, the parade of bracken broken bikepackers saw the path directly below them and chuckled.....
Is anyone else like me just accepting Stu's idea of fun and going along with whatever the GPS says without questioning the master route creator?
I believe your lines on the GPS Stu if no one else does
Having done a few of these... NOPE.
That's the way I have always played it too Karl...Karl wrote:Is anyone else like me just accepting Stu's idea of fun and going along with whatever the GPS says without questioning the master route creator?
Si
Stupid us Si!
See you Saturday
See you Saturday
