Welsh Winter Bivvy 2016 UPDATES
Re: Welsh Winter Bivvy 2016.
Just working the route out now - details tomorrow
Re: Welsh Winter Bivvy 2016 UPDATES
Refer to first post for full details.
No pub to deliberate in whilst it lashes it down outside? :)
No, we'll have to be brave ... although I'm hoping we may encounter a pub a little laterNo pub to deliberate in whilst it lashes it down outside? :)
We will have to be wet :) FTFY.
Noted one should rock on up prepared for zero services. "May" in mid-Wales usually says to me "Good luck".
Does it have wifi?Bearbonesnorm wrote:No, we'll have to be brave ... although I'm hoping we may encounter a pub a little laterNo pub to deliberate in whilst it lashes it down outside? :)
Doesn't mention owt on the sign.Does it have wifi?
If conditions are favourable, is everyone happy kipping above 500m?*
*I shouldn't really need to ask but I feel that given the amount of effort and organising going on down south, I should at least ask the odd question.
That'll be chilly.
What the temps like at the moment near you?
Pretty cold out of the sun, probably around zero ... I'm banking on an inversion and it being warmer higher up.What the temps like at the moment near you?
You driving to the start Stu?
Unsure yet. I assume you'd like your tent bringing if I am? If not, I can post it down?You driving to the start Stu?
If you are then great...
If not then no stress, got alternatives
No worries about going high from this end of the stick. After seeing Bala @ -7C last night, I'm wondering if there's merit in some studded tyres this year. What's the on/off road ratio looking like Stu?
If we go where I'm thinking, I'd estimate a 60/40 in favour of off-road. Hopefully it won't be a boggy mess but there might be a shortish section of trackless, heathery fun but it shouldn't be more than a km ... and I'm hoping there is a path of some sortWhat's the on/off road ratio looking like Stu?
Ta for that. I'd rather no repeats of my visit to the floor of Twixmas from years past.
Aye, I didn't envy that.I'd rather no repeats of my visit to the floor of Twixmas from years past.
- Dave Barter
Double FECK our biggest customer has decided that their database upgrade happens on the 11th November. I'll be winter bivying in front of a terminal
You've not had much luck this year, have you?Double FECK our biggest customer has decided that their database upgrade happens on the 11th November. I'll be winter bivying in front of a terminal
- Dave Barter
No, can't even write dates down properly ;-)Bearbonesnorm wrote:You've not had much luck this year, have you?Double FECK our biggest customer has decided that their database upgrade happens on the 11th November. I'll be winter bivying in front of a terminal
and I'm no good at readingNo, can't even write dates down properly ;-)
- 99percentchimp
If it stays still Stu there was a 4 degree difference between sea level and 250m here this morning - cold in the valley.Bearbonesnorm wrote:Pretty cold out of the sun, probably around zero ... I'm banking on an inversion and it being warmer higher up.What the temps like at the moment near you?
Conquistador of the pointless
Forecast is looking quite favourable so far, not too windy, only a little rain on Sat and fairly mild overnight (quite different from last year)
Anyway, I'll pop out tomorrow for a final recce which will determine exactly where we go and under what hedge we spend the night. I will contact those who were wishing to join the main party after work with details of our overnight location.
Over and out.
Over and out.
