My bike is still in the shed!
Viz top tip
Re: Viz top tip
What, like WRT grid refs.?
Re: Viz top tip
You'll be invoking Godwin's Law next or worrying about the childrenLazarus wrote: ↑Wed Apr 19, 2023 6:50 pm I just find the "worse things happens" something you can always say, to anything, unless its as extreme as the two things I stated. I could have used the zombie apocalypse and thermonuclear war but doubt that would have met with universal approval/understanding either [ and the two I mentioned are happening currently ]
I dont have much confidence this post will lead to clarity, or help much, but that is the intention.
But more to the point:
I find it to be a phrase some people use to imply they don't think it is a "big deal". Not one that literally means, because it's not THE MOST IMPORTANT THING EVAH, that the issue at hand is utterly irrelevant. But then I'm all about shades and not the absolutesI just find the "worse things happens" something you can always say
Even with a lingua franca misunderstandings occur. Imagine if we were all trying to do it in Welsh
Re: Viz top tip
steady on now,I have some limitsYou'll be invoking Godwin's Law next or worrying about the children
Reasonable point and I shall interpret it as such going fwdto imply they don't think it is a "big deal"
Re: Viz top tip
Ah, that makes sense. I’ve always taken that sort of comment as a ‘negative’ but you’ve put on a different and probably more accurate meaning Thanks
