You could just buy a pack of these
https://www.gooutdoors.co.uk/15905412/g ... 4-15905412
And 1 of the cheap adapters off ebay and you'll get about 9 100g refills for a tenner. Thats what I do. Not that im tight or anything
Its a winter mix aswell and you can always go our with a full 1 if needed.
Refilling a smaller gas bottle
- JohnClimber
Re: Refilling a smaller gas bottle
That all depends if the tops of these are the same screw thread to match the adaptor and the smaller canisters.HUX wrote: ↑Mon Mar 29, 2021 8:39 pm You could just buy a pack of these
If they are push on light some lighter fillers then you'll need a different adaptor
- thenorthwind
Didn't realise you could get propane mix in that sort of canister I've already got the little push adapter that Stu mentions for butane. Ah well, the screw adapter will probably be a bit less wasteful, it's tricky to get the push adapter in exactly the right place so you always spray a bit out the side.HUX wrote: ↑Mon Mar 29, 2021 8:39 pm You could just buy a pack of these
