Tool lust...
Re: Tool lust...
Cheers I had thought of chain line but was worried that with out the derailleur it might not stay on the one you wanted it to. I listened to a podcast today where it happened to a guy and he just could get it to stay on one sprocket with many refits.
Re: Tool lust...
This is a brilliantly designed tool for removing cassettes if you break a drive side spoke or the chain gets mashed into the cassette, includes spoke key. Sadly no longer available but I've got one for trips sans Rohloff.
Re: Tool lust...
I usually carry a Hyper Cracker in my tool kit too, on some longer trips i've also included an SS cog & spacers as they weigh very little. Well, they weigh less than a spare derailleur & would mean i could carry on riding..
Re: Tool lust...
Turned up. Got stung for £5 vat and £8 handling fee by post office.
Tis nice though.
Tis nice though.
Re: Tool lust...
I used to have one of those piston but sold it when I went rohloff now I'm back on normal stuff I wish I still had it :(
- BigdummySteve
Re: Tool lust...
Re: Tool lust...
No chain whip, you change gear to the lowest/biggest sprocket on the cassette, drop the wheel out and put the tool onto the lockring whilst making sure the right angle bit contacts the chainstay or seatstay then refit the wheel, pedal forwards a bit and the lockring loosens. Take the wheel out and remove the cassette. It's a bit agricultural but it works.
Re: Tool lust...
Ha that over simplifies it somewhat You missed the part about swearing a lot trying to manoeuvre it all into position without skinning your knuckles or trapping a finger end. I've used mine in the wilds and they are handy. I have a feeling there is another similar thing available somewhere...pistonbroke wrote:No chain whip, you change gear to the lowest/biggest sprocket on the cassette, drop the wheel out and put the tool onto the lockring whilst making sure the right angle bit contacts the chainstay or seatstay then refit the wheel, pedal forwards a bit and the lockring loosens. Take the wheel out and remove the cassette. It's a bit agricultural but it works.
Re the original post, I carry a leatherman anyway and the pliers serve just as well. No reason not to buy a bling new tool however
Re: Tool lust...
Ta-dah: https://www.spacycles.co.uk/products.php?plid=m2b88s0p0htrider wrote:I have a feeling there is another similar thing available somewhere...
Re: Tool lust...
Have straight pull spokes on my gravel wheels (DT Swiss 240 centre lock) so it should be possible to change a spoke without removing cassette or rotor.pistonbroke wrote:
- BigdummySteve
Re: Tool lust...
techno mail wrote:Ta-dah: https://www.spacycles.co.uk/products.php?plid=m2b88s0p0htrider wrote:I have a feeling there is another similar thing available somewhere...
Thanks for the link, a most excellent advert.
“The NBT2 is NOT suitable for use with super lightweight [stupid-liteTM] alloy racing frames, where the deraileurhanger already self destructs with normal use.
Prior to first time use it is recomended to check with conventional tools that the lockring hasn't been tightened way over the recommended torque by some hamfisted mechanic, to prevent overloading the dropout."
