Just saw this thing... https://www.tarptent.com/product/notch-li/
I don't do enough bikepacking to justify the spend, but if I did, that's what I'd be going for!
Lightweight shelters
Re: Lightweight shelters
Only 5 months on from this thread... and finally I've become part of the SMD club too with an old stock/hardly used deal from Stus classifieds all for the handsome sum of only £110 (of which I sent £115 vos thats what Muhammed / the Quran taught... of 'giving good measure' etc)...
Thanks again Bearbonesnorm finally I can used the pole that was made months and months ago...
Be aware that the first generation Lunar used a slightly shorter pole than the latest ones. Try what you've got but if it seems odd, we might need to shorten your pole slightly - see how you go on as there's often some leeway with these things.Thanks again Bearbonesnorm finally I can used the pole that was made months and months ago...
Stu... you forget that you made the pole for at least 3 different configurations but will let you knowBearbonesnorm wrote: ↑Sat Aug 31, 2019 11:27 amBe aware that the first generation Lunar used a slightly shorter pole than the latest ones. Try what you've got but if it seems odd, we might need to shorten your pole slightly - see how you go on as there's often some leeway with these things.Thanks again Bearbonesnorm finally I can used the pole that was made months and months ago...
Oh yeah, knock yer self out then fellaStu... you forget that you made the pole for at least 3 different configurations but will let you know
