You just beat me to it - good priceAlasdairMc wrote:Maxxis Chronicle 29+ for £26.50 from Chain Reaction. This is the 3" Exo TR 120tpi version.
Bargain Alert Thread
Re: Bargain Alert Thread
I just topped up my specialized Rime collection at Je James for £30 a pair.
What's a suitable rim width for these? I suspect my current 25mm rims are a bit narrowAlasdairMc wrote:Maxxis Chronicle 29+ for £26.50 from Chain Reaction. This is the 3" Exo TR 120tpi version.
They fit very well on my 50mm rabbit hole rims
Is that 25mm internal? I used to run 3" tyres on Flows which was fine but didn't allow the lowest pressures to be runwhitestone wrote:What's a suitable rim width for these? I suspect my current 25mm rims are a bit narrowAlasdairMc wrote:Maxxis Chronicle 29+ for £26.50 from Chain Reaction. This is the 3" Exo TR 120tpi version.
See my separate rim width thread as to what I'm after.
Beware of the cheap max is chronicle tyres from chain reaction mine came standard not tubeless ready
Uberbike Components have 25% off all weekend. Use 'MAYDAY25' code.
But can it be used tubeless?windjammer wrote:Beware of the cheap max is chronicle tyres from chain reaction mine came standard not tubeless ready
- ZeroDarkBivi
Specialized Rime reduced from £100 to £30, in limited sizes:
http://www.jejamescycles.com/specialize ... -shoe.html
Hope they are good as my HAB friendly Mavics have been sent back for a warranty claim after the ratchet buckle snapped!
I have the older version of these with the boa ratchet. I love them. They've done the HTR twice now and the heel padding is starting to wear away a little. I was planning to use them again this year but I've just bought a pair of these too so that I have some backup.ZeroDarkBivi wrote: Hope they are good as my HAB friendly Mavics have been sent back for a warranty claim after the ratchet buckle snapped!
- 99percentchimp
A few more sizes here but not quite as cheapZeroDarkBivi wrote:Specialized Rime reduced from £100 to £30, in limited sizes:
https://www.edinburghbicycle.com/specia ... -shoe.html
Conquistador of the pointless
56% off montane minimus jackets at wiggle
I just got one of these down blankets for £20 as a top-up for our sleeping system when needed. It weighs 460g including the stuff sack on my scales. I think it is the same 'Costco throw' that the bespoke ultralight guy makes his hammock blankets from.
http://www.ebay.co.uk/itm/162403044814? ... EBIDX%3AIT
jetboil minimo reduced by £50 at cotswolds. down to £89
Dash4it the OS map seller has 10% off just now:
Code 10BDAY
https://dash4it.co.uk/ordnance-survey-m ... lorer.html
Code 10BDAY
- whonickedmename
Thanks, some maps ordered to cover the Trans-Cambrian route...(just in case)Borderer wrote:Dash4it the OS map seller has 10% off just now:
Code 10BDAY
I have just bought this lightweight, credit card sized power bank for my mobile phone. It was £10 delivered. It is one to keep in the bag for those emergency 'oh crap I have broken my leg and my phone is dead' sort of moments. Weighs 86g on my scales and will put 20-30% into my Moto G4's battery. It has an integral wire and comes with an iPhone connection too for you posh people.
http://www.ebay.co.uk/itm/142188477909? ... EBIDX%3AIT
The Trans-Cambrian isn't *too* hard to follow especially if you've done any of the BB events since it passes quite close to BB Towers. There are a couple of "Wheeeee! Brilliant downhill" before you realise that the route turned off 200 metres back uphill moments Should be much drier than when I did it in Marchwhonickedmename wrote:Thanks, some maps ordered to cover the Trans-Cambrian route...(just in case)Borderer wrote:Dash4it the OS map seller has 10% off just now:
Code 10BDAY
- whonickedmename
Thanks Whitestone, I'm new to the area - must get along to the next WRT or similar though!
ianfitz wrote:I just topped up my specialized Rime collection at Je James for £30 a pair.
Thanks both, I was lucky and my size was available so I thought I'd give them a whirl as I know spesh shoes fit me nicely, but I've been using shimano for a few years now because I find them harder wearing and better VFM, but at £30 and another set of shoes on there way out, I'll see how these go.ZeroDarkBivi wrote:Specialized Rime reduced from £100 to £30, in limited sizes:
- ZeroDarkBivi
Does anybody know if Apidura do a discount for 'boners?
Nope.Does anybody know if Apidura do a discount for 'boners?
Edit - that's nope as in no discount rather than nope I don't know.
It turns out that I didn't as they were out of stockianfitz wrote:I just topped up my specialized Rime collection at Je James for £30 a pair.
